Receptacles: Self Grounding Clip Detailed - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2006, 02:57 PM   #1
Receptacles: Self grounding clip detailed
Hello together!
On various receptacles I found a self-grounding clip. I am not completely sure about its funktion.
From what I can see, there is no plastic screw holder any more between receptacle box and grounded metal, because the self grounding clip protects the screw from falling out.
So there is enough contact between (metal) box and recpetacle which means if the box is grounded, the receptacle itself is grounded (or the other way round).
Is the clip also suitable for grounding metal cover plates or is this done via the grounded screw thread for cover plates?
Does it have any other function I missed?
Wish you a nice weekend
Marekus
Marekus is offline   Reply With Quote
Old 12-04-2006, 12:57 PM   #2
Does anyone know the answer?
Old 12-07-2006, 03:15 PM   #3
Marekus,
The "self-grounding clip" is an agency approved device designed to automatically ground the receptacle to a grounded metal box without having to connect a ground wire to the receptacle. That is, if the ground wire or metal conduit is secured to a metal box, this type of receptacle will be "self-grounding" without an added ground wire.
The "self-grounding clip" clinches against one of the screws securing the receptacle to the box.
...Christopher
Christopher is offline   Reply With Quote
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
Toggle switches: With or without grounding screw? Marekus Electrical 3 11-27-2006 03:48 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 01:21 PM
