Old 02-23-2009, 08:08 PM   #1
Receptacles in plaster on brick construction
I've searched these forums and elsewhere trying to find a definitive answer to this question -
What materials can be embedded in plaster?
From my reading of the NEC, the following are OK:
AC
MC
NMC (whatever that is)
I'm not clear on other conduits. Is PVC OK?
My house is plaster on brick on brick and the bricks are solid. As such, I have hardly any receptacles on exterior walls. I desperately need one in my office and would like to pop off the baseboards and embed whatever wiring method is simplest and code-compliant to extend from an existing receptacle.
Bonus question: what type of shallow boxes work well in this application?
pmoe is offline   Reply With Quote
Old 02-23-2009, 08:27 PM   #2
Licensed Pro
Easiest way would be to use a surface mounted system such as Wiremold along the baseboard.
http://www.wiremold.com/diy/products...ic_raceway.asp
Old 02-23-2009, 08:33 PM   #3
I'm not a big fan of the aesthetics of raceway...
Old 02-23-2009, 08:52 PM   #4
Licensed Pro
A few hours of trying to cut into the plaster and brick will make you a fan.
Last house I did with plaster over brick was a royal PITA! The Wiremold on the baseboard can be painted to match and once furniture is in place, you won't even notice it.
Old 02-23-2009, 08:56 PM   #5
I just need one of these -
http://www.youtube.com/watch?v=dXA_8MW2rDg
new construction no Brick ledge Justbeck101 Building & Construction 25 11-19-2012 02:03 PM
Brick Step Construction edstevn Building & Construction 1 11-28-2008 11:33 AM
Sealing historic brick tenzo General Discussion 2 11-22-2008 04:04 PM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
troweling plaster on brick mattroos General Discussion 3 02-11-2007 12:11 PM
