-   -   Receptacles in plaster on brick construction (http://www.diychatroom.com/f18/receptacles-plaster-brick-construction-39018/)
pmoe 02-23-2009 07:08 PM
I've searched these forums and elsewhere trying to find a definitive answer to this question -
What materials can be embedded in plaster?
From my reading of the NEC, the following are OK:
AC
MC
NMC (whatever that is)
I'm not clear on other conduits. Is PVC OK?
My house is plaster on brick on brick and the bricks are solid. As such, I have hardly any receptacles on exterior walls. I desperately need one in my office and would like to pop off the baseboards and embed whatever wiring method is simplest and code-compliant to extend from an existing receptacle.
Bonus question: what type of shallow boxes work well in this application?
HouseHelper 02-23-2009 07:27 PM
Easiest way would be to use a surface mounted system such as Wiremold along the baseboard.
http://www.wiremold.com/diy/products...ic_raceway.asp
pmoe 02-23-2009 07:33 PM
I'm not a big fan of the aesthetics of raceway...
HouseHelper 02-23-2009 07:52 PM
A few hours of trying to cut into the plaster and brick will make you a fan:yes:.
Last house I did with plaster over brick was a royal PITA! The Wiremold on the baseboard can be painted to match and once furniture is in place, you won't even notice it.
pmoe 02-23-2009 07:56 PM
I just need one of these -
http://www.youtube.com/watch?v=dXA_8MW2rDg
