Receptacles Made In USA - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 09:39 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
We use "construction grade" devices. I'm really not sure what the difference between commercial grade, construction grade, and spec grade really is.
Old 07-06-2013, 09:52 PM   #17
Rewards Points: 6,652
The price, and that with Commercial & Spec grade, they have back screwed attachment, not side screwed. Also Commercial or Spec grade is going to be a more sturdy body and inner metal parts, than standard or construction grade.
Old 07-06-2013, 10:16 PM   #18
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Spec grade and commercial grade are the same thing. Built to withstand constant use such as vacuums, polishers, scrubbers etc. they will last longer without loosening up with continuous use.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-06-2013, 11:28 PM   #19
electures, my wife keeps telling me to swap out the Commercial grade 3-ways in the Kitchen & dining, because they are fatter than the single poles, and have that feel to them that you know they are on or off.
I only use the Leviton Pro GFCI when I can for GFCI outlets in my place. I have found them personally better than the P&S GFCI, because they have that green light that tells you they are working.
I have tried to find the ones that my B-i-Law has, that is Red when tripped, Green when good, Yellow when you push the Test button, but have not been able to, no matter how much I have looked for them.
Now I have noticed that Leviton has come out with one that will do a self-test every 15 minutes, and sound an alarm if there is a problem found. I can see those becoming the standard soon, then seeing people finding ways to either poke something in to destroy the piezo speaker inside the unit, or clog the holes where the speaker is, to try to quiet it down.
Old 07-07-2013, 01:15 AM   #20
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Geee, just wait till they come out with the even better model of that next year! it will speak to itself and say something like:
"Your mission Jim, if you choose to accept... is to seek out and DESTROY any defects"
Then it probes and discovers IT is defective and destroys itself after sounding a loud "defect found" alarm!
They'll cost $99.95 each, made in China for that 100% reliability factor.
RWolff is offline   Reply With Quote
Old 07-07-2013, 01:22 AM   #21
They already have RWolff. It is called a Wife/Girlfriend. Even worse when the mother in law comes out and says that some alarm is going off in your bathroom, as soon as she flushed the toilet.
Old 07-07-2013, 07:38 AM   #22
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You could always strategically install some of these around the house and change the plug on the vacuum.
They are pretty expensive, $20-$50 on the web.
I've only seen black and brown though.
Just a thought
wirenut1110 is offline   Reply With Quote
Old 07-07-2013, 10:59 AM   #23
Rewards Points: 160
I installed 39 receptacles in my house 9-10 years ago and have yet to have one single issue with any of them.
Unless you are vacuuming multiple times a day using the same receptacle, I do not understand why you have this issue.
In fact I cannot remember having a receptacle that was loose. Tight yes, but rarely lose.
Old 07-07-2013, 11:09 AM   #24
electures's Avatar
Same here. I built my home 28 yrs ago using builders grade devices. Never had a problem. Or maybe my wife never vacuums?
Old 07-07-2013, 12:50 PM   #25
Rewards Points: 117
We have a German Shepherd (sheds like hell) and vacuum at least once a day. I think I'll try the spec grade ones for plugs that will get used often. Thanks for all the input.
tommyxv is offline   Reply With Quote
Old 07-07-2013, 02:26 PM   #26
We have a golden and all I used were the contractor packs. Ten years later still holding up.
I have only had to change out one, due to a chair got slammed against it, while a window fan was plugged into the outlet.
ground wires... echobravo Electrical 35 12-20-2012 07:54 AM
Made in the U.S. Skil power tools pjm30043 Tools 7 07-18-2012 09:05 PM
Milwaukee tool made in China KUIPORNG Tools 63 08-31-2011 01:10 PM
3way half switched receptacles Rhyno973 Electrical 2 10-05-2010 02:33 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 01:21 PM
