Receptacles Made In USA - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2013, 05:44 PM   #1
Rewards Points: 117
Receptacles Made in USA
Does anyone know which brands are made in the USA?
tommyxv is offline   Reply With Quote
Old 07-06-2013, 12:09 PM   #2
Rewards Points: 78
Not sure there are any?
Old 07-06-2013, 01:24 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Leviton, Hubbell, and P & S claim they're made in the USA.
Probably assembled in the USA with China parts.
wirenut1110 is offline   Reply With Quote
Old 07-06-2013, 02:00 PM   #4
Rewards Points: 117
Thanks. I replaced all the old worn outlets (wouldn't hold plugs very well) on the first floor with P&S Legrand receptacles, but the ones we use for the vacuum are wearing out already. They don't hold the plug tight anymore.
I am getting ready to wire the mancave and was seeing if there were better options.
Old 07-06-2013, 02:19 PM   #5
Rewards Points: 6,652
All name brands are made here in the U.S. still, but assembled in Mexico, Canada, China, etc, for some.
Remember just because it states made in the US of A, does not mean assembled in the states.
Old 07-06-2013, 02:21 PM   #6
Replace with a new outlet, either P&S or Leviton. Just because the outlet is not holding plugs, does not mean that it is junk. Most of us use Commercial grade outlets in those locations that get heavy use, vs. common residential outlets.
Commercial outlets will stand up to the abuse people put them through, by multiple plugging & unplugging devices.
Old 07-06-2013, 02:48 PM   #7
Rewards Points: 678
Compare the appliance spades of the new asian junk to the older prongs ( spades ) of the older USA made appliances and you may find the receptacle isn't the problem at all.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
Kyle_in_rure (07-06-2013), MTN REMODEL LLC (07-06-2013)
Old 07-06-2013, 03:44 PM   #8
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
None, almost everything is made in China, or some foreign country these days.
You go to the top brands like Leviton, nowhere does their site say anything liek "proudly made in the USA" but it says "sales in 80 countries" which means the USA is only 1/80th
Ditto for Cutler-Hammer/Eaton corp- big international sales, the USA is only one small part of the total, they have offices etc in other countries, you can bet like the others they have their manufacturing plants where the cheapest labor and costs are.
No doubt you'll find all the rest of the brand names you see at the hardware store are about the same story.
If you ever find antique outlets and things you'll find a huge difference in how they used to make them with porcellain bodies instead of cheap plastic, even the boxes were thicker steel.
Now you go to the hardware store and there's these $1.29 plastic switches and outlets... even the so called "commercial grade" ones aren't as well made as the old stuff.
RWolff is offline   Reply With Quote
Old 07-06-2013, 04:21 PM   #9
Rewards Points: 117
My house is 40 years old and the ones I replaced on the 1st floor all looked original. They definitely lasted a long time. They looked like they were made better and felt heavier then the ones I replaced them with.
I'll check out those commercial spec ones for outlets that get used often. Maybe I will grab a contractor pak for the basement. I'm doing a HT room, Poker room, full bathroom, wet bar, and office. All the wall are up and now it's wiring time.
Old 07-06-2013, 05:28 PM   #10
RWolff's Avatar
Rewards Points: 502
You'll never find any that will last that long or made that well again, those made 40 years ago were made here in the USA and before most people even knew where China WAS!
Old 07-06-2013, 05:36 PM   #11
Even forty years ago, we were having stuff assembled or parts manufactured in foreign countries, but not like todays.
You can tahnk the Wal-mart effect, along with Nafta and Trans-Pacific trade agrement.
Old 07-06-2013, 06:07 PM   #12
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 54
I looked at a box of Leviton outlets I got here and it says Made in USA.
Of course that is always to be taken with a grain of salt.
Old 07-06-2013, 06:45 PM   #13
Rewards Points: 3,130
I don't understand. I have owned ten houses in the past 40 years and have never, not even once, had to replace a receptacle because it was worn out. What are people doing that theirs wear out??
Old 07-06-2013, 06:59 PM   #14
Pluggin and unplugging stuff, by yanking on the cords, or pushing down or pulling up on stuff, when removing from the outlet.
We mainly use power strips in my house, so if anything is going to wear out, it will be the strip.
Old 07-06-2013, 10:23 PM   #15
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Try using commercial grade devices. They will last longer.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
ground wires... echobravo Electrical 35 12-20-2012 08:54 AM
Made in the U.S. Skil power tools pjm30043 Tools 7 07-18-2012 10:05 PM
Milwaukee tool made in China KUIPORNG Tools 63 08-31-2011 02:10 PM
3way half switched receptacles Rhyno973 Electrical 2 10-05-2010 03:33 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 02:21 PM
