Receptacles On Either Sides Of An Inside Corner - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 08:48 AM   #1
Rewards Points: 1,648
Receptacles on either sides of an inside corner
I have an inside corner, both walls are exterior - concrete blocks.
I wanted to have a receptacle on each wall, at same height, about 6" or so from the corner.
Since my home is all EMT and metal boxes, I'd prefer to use a EMT conduit to bridge the boxes but I can't do that with the concrete block inside corner. There is not enough room to make a sweeping curve, the furring strip is only 1/2" thick behind the sheet rock. To use EMT I need to go all the way up to the attic, then over for like 8" then all the way back down. I don't think those metal corner elbow boxes would work for this. Is there another trick I am not aware of?
Another possible solution is to cave in and use a short piece of romex between the two, hugging the wall around the corner. As long as I connect the ground wire of the romex to both boxes, I still have "ground continuity" across the whole system right? I have conduits everywhere else.
miamicuse is offline   Reply With Quote
Old 08-13-2013, 09:15 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
If you code requires conduit, use conduit. If not "Romex" is fine.
You could use FMC (Flex. Metal Conduit; ie: Greenfield)
You will have to remove drywall to get around the corner.
How are you going to have enough depth for mounting the boxes?
Have you considered surface mounted Wiremold?
Coastal South Carolina
Old 08-13-2013, 10:11 AM   #3
Rewards Points: 204
If your in Miami FL. Romex is fine.
However, your idea of going up and over with conduit is a great idea. A pro will not do this as it takes to long.
MC cable is second best to conduit and is flexible as rj mentions above.
How do you plan to mount the boxes in the block? Or are you mounting them to the block surface?
Secure the boxes and get a cable or conduit to each one and call it a day. Good luck.
Don't forget they must be GFCI protected.
Old 08-13-2013, 10:58 AM   #4
To clarify, there is no drywall there NOW, all that's been removed as part of the remodel.
So I can attach the boxes directly to the blocks with Tapcon screws.
The depth is not a problem. The existing metal box is shallow, like 1" thick (I took it to a supply house and they said they made these years ago but not anymore). The furring is 1/2" the sheet rock is 1/2" thick so it works. The new one I am adding is tricky. It's standard depth so I have to cut a hole in the block to recess the box. That's why I wanted it 6" from the corner that way I can hit the thinnest 4" square of the block and avoid the edge and the web.
Old 08-13-2013, 09:19 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Those boxes will not be legal...and most likely the reason they are not made anymore.
Old 08-14-2013, 10:09 AM   #6
Rewards Points: 204
Sorry. I thought you meant they were outside.
If you have no drywall in place, install 1900 boxes and mud rings. Use a mud ring one size thicker than the drywall will be for perfect fit. Perfectly flush is what I mean.
Or you can use plastic boxes and Nm cable. This is the easiest way.
Old 08-14-2013, 04:39 PM   #7
Rewards Points: 170
Smile
Due to the shallow depth of the wall, I would use conduit for sure to avoid nails and/or screws being driven into the wire and causing a short circuit... or worse. Instead of a flex conduit, use a ridged conduit and a 90 degree elbow. since the boxes are only 6" in from the corner, you will only need 1-2 feet of conduit. Good luck with your project!
diyer111 is offline   Reply With Quote
Old 08-14-2013, 07:16 PM   #8
A "Handy Husband"
rjniles's Avatar
If by a "90 degree elbow you mean a pull elbow
or a LB fitting
They must be left exposed
Old 08-14-2013, 07:21 PM   #9
Licensed electrician
Rewards Points: 1,794
It is possible to bend conduit for an inside corner. Basically you have 2 back to back 90's that are 90 degrees to each other. One is flat the other turns up.
Inside corner and subway brick pattern tile russiand Tiling, ceramics, marble 12 08-20-2013 10:17 AM
Inside Corner in Bathroom dublin Drywall & Plaster 2 02-18-2012 05:31 AM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Replacing a corner post, Reinforcing the wall? jlawrence42 Building & Construction 5 08-21-2006 11:41 AM
