Receptacles Behind Gas Range Install - Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2009, 04:49 PM   #1
Hi - I'm a big reader of these forums - but this is my first post!
Please see the referenced illustration for a picture of what I'm describing:
http://img188.imageshack.us/img188/3...electrical.jpg
I'm recently renovating my kitchen - the original kitchen was equipped with an electric oven, hard-wired into receptacle "A", a Gas Cooktop plugged into receptacle "B", and an undercabinet mounted Microwave/Vent plugged into receptacle "C". There are two circuits running down the illustrated conduit into box "A" - the oven's dedicated circuit, as well as the Cooktop Igniter/Microwave deicated circuit which runs down through "A", to "B", and then to up to "C".
Now, my question:
The new kitchen is equipped with a 30" All-Gas Wolf Range, and a Pro-Wall Vent Hood. With this new setup, I now longer wish to utilize receptacle "A", as the new range only requires a 120v three-pronged outlet for the igniter.
So, what do I do with "A"? The gas line and receptacle "B" are in perfect position for the new range. But, if I were to install the range, receptacle "A" would be immediately behind the range's upper-most flat-backed steel panel.
Can I cap the unused wires in "A" and place a blank plate over "A" - or is that not to code being that it is technically a junction box right behind the range? If I can cover "A" with a plate, is there any need to worry about the heat coming off of the oven affecting either the plate or wires behind it?
Any other suggestions?
Thanks in advance!
IIchrisII is offline   Reply With Quote
Old 07-27-2009, 04:55 PM   #2
That was a long read for an easy answer.
Cap the wires and install a blank cover on "a"
220/221 is offline   Reply With Quote
Old 07-27-2009, 05:07 PM   #3
I'd simply leave the 240v range outlet
Unless you need the breaker/power for something else
Next owners may want an electric range
But with a Wolf installed I doubt it
You can cap it as 220/221 said
The blank face junction box is fine behind the range
It is still considered accessible
No need to worry about the heat
All stoves are made (unless from China or some other such place ) to be insulated to protect the walls etc behind the stove
Old 07-27-2009, 05:38 PM   #4
Great - thanks for the help!
Old 07-27-2009, 08:37 PM   #5
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
I'd keep it as well, you never know, and it's hidden anyway so not like it's an eye sore.
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
Toilet install question rolls831 Plumbing 9 07-09-2008 08:00 PM
F chanell install question... TonyW Building & Construction 1 08-01-2007 10:34 PM
How do you install a range hood? Krichton General DIY Discussions 5 09-29-2006 09:30 PM
Laminate Selection & Install Question sdcards Flooring 1 10-13-2005 04:12 PM
