Receptacle And Water Faucet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-03-2012, 09:13 AM   #1
receptacle and water faucet
if a 110v receptacle is located near a water faucet on the inside of a building, does it need to be GFCI protected? no sink involved.
Pepperellie12 is offline   Reply With Quote
Old 05-03-2012, 09:29 AM   #2
I=E/R
a7ecorsair's Avatar
You have an inside faucet and no sink?
a7ecorsair is offline   Reply With Quote
Old 05-03-2012, 09:35 AM   #3
faucet is for a hose to wash off parts or walls
Old 05-03-2012, 09:38 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Define "near".
I believe in the "spirit" of the code, the receptacle should be GFI protected within 6' of the faucet.
Old 05-03-2012, 09:42 AM   #5
i too believe it should be protected as it is within 6ft of the faucet, but the nec is a little vague on this exact scenario. this is an industrial bldg.
Old 05-03-2012, 09:43 AM   #6
k_buz's Avatar
What type of industrial building? That may dictate more than just a general GFI code.
Old 05-03-2012, 10:00 AM   #7
an industrial fabrication plant. an ice making machine is also located beside the faucet and is utilizing this receptacle
Old 05-03-2012, 10:09 AM   #8
k_buz's Avatar
After specifically looking, I think any 120 V recept in the area that you wash the parts or walls would need to be GFI protected.
210.8 (B)(6) specifies indoor wet locations in non-dwelling units, need to be GFI protected.
Location, Wet. Installations underground or in concrete
slabs or masonry in direct contact with the earth; in locations
subject to saturation with water or other liquids, such
as vehicle washing areas;
and in unprotected locations exposed
to weather.
**I just installed my RHEEM ECO-SENSE 180DVN3 tankless water heater 57_Hemi Plumbing 21 01-03-2013 11:32 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 11:19 AM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Rewiring kitchen for disposal and water filter dantm Electrical 7 02-07-2010 02:55 PM
Wiring outside receptacle water proof box. erlindbl Electrical 3 02-27-2009 01:35 PM
