Old 05-31-2005, 03:13 PM   #1
Question
receptacle upgrading blunder - help!
Please help! - My house was built in 1987. I began replacing the old receptacles with new ones. After finishing, I noticed 3 of the receptacles went dead - 2 in the dining room and the one for the fridge. (there are only 2 receptacles in the dining room).
I should point out that when I tried to remove the receptacle in the dining room, I got a slight shock. I was suprised by this as I switched the circuit breaker for the lights and receptacles to the "off" position. After switching the Mains to off, I continued to remove the dining room outlets only to find out their wires are slightly thicker than the others. I used a drill to widen the holes on back of the new receptacles and finished installation (I think this may have been a bad idea).
After powering up, I noticed the fridge was not on. Then I checked all of the outlets and switches I upgraded. All of them were working except for the three receptacles.
I checked the circuit breaker and resetted all of the them including the main. Still nothing.
Please help - could I have shorted the circuit branch feeding these 3 outlets? Why is the fridge outlet related to the dining outlets?
Any feed back or suggestions will be greatly appreciated.
Thanks in advance.
jlondon is offline   Reply With Quote
Old 05-31-2005, 08:30 PM   #2
Remodeler
MinConst's Avatar
I agree this was a bad idea Before you go much further I would recommend getting a professional in on this. No offence intended but it sounds like your playing with fire. Litterally.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 06-01-2005, 07:16 AM   #3
Electrical Contractor
The reason the wires would not fit is they are # 12 and the recepticles will only accept #14. As stated before, it is time to get an electrician in. The only way to fix this is replace what you replaced and use pigtails and not the holes.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Post mounted electrical receptacle ¯¯NI¯l¯RO¯¯ Electrical 13 04-19-2010 03:20 PM
Receptacle broken mwagner Electrical 10 05-25-2007 08:41 AM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 10:28 AM
20A or 15A receptacle ejlog Electrical 3 02-21-2005 07:29 PM
