Receptacle Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 10:39 AM   #1
receptacle switch
I'm trying to find a device that's like a receptacle switch except that the switch activates the receptacle, not another device like a light.
mattherring is offline   Reply With Quote
Old 09-12-2010, 11:47 AM   #2
Mad Scientist
Are you referring to the receptacle/switch combos that have an outlet on the bottom and switch on the top? If so, I believe you can wire those so that the switch controls the outlet.
The device should have a brass strap connecting two of the screws on one side. Hold the device with that side to the right. Assuming the switch is on top:
Connect the incoming neutral to the lower left screw, and the incoming hot to the upper left screw. Connect the ground wire to the ground screw. Done!
If what I'm saying doesn't match up with what your particular switch/outlet looks like, let us know and we'll go from there.
McSteve is offline   Reply With Quote
Old 09-12-2010, 06:25 PM   #3
Rewards Points: 1,532
All of these receptacle switch combos let you choose whether you want the switch to control the receptacle or to control something else (or to control both the receptacle and something else).
Is it possible to add a receptacle to a 3-way switch? ellem Electrical 7 09-05-2010 05:17 PM
Adding a Hot Receptacle to a 3-Way Switch Coady Electrical 2 09-03-2010 12:11 PM
Switched receptacle wiring problem. sheshore Electrical 6 09-27-2009 01:37 PM
Switch / Receptacle mikbro Electrical 11 10-31-2008 04:15 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
