-   -   Receptacle stopped working (http://www.diychatroom.com/f18/receptacle-stopped-working-95122/)
lovetobuild 02-10-2011 09:24 PM
I was checking where the fuse was for a certain circuit the other night. So I turned off a couple of fuses and found it. The next morning, I discovered that one of the receptacles on that circuit had stopped working. I thought it might have been a coincidence that the receptacle quit working because of the power interruption, so I replaced it...and the new one is not working either. The receptacle was working before I had turned off the fuse. Would anyone have any suggestion as to what the problem might be.
oh yes, all the other things on that circuit are working fine.
AllanJ 02-11-2011 07:22 AM
If it was a blown fuse or a tripped breaker that prompted you to start this investigation or project, then the overload may have aggravated a loose connection in the receptacle in question or at the previous receptacle or outlet box on the daisy chain back to the panel.
lovetobuild 02-11-2011 07:31 AM
PHP Code:
If it was a blown fuse or a tripped breaker that prompted you to start this investigation or projectthen the overload may have aggravated a loose connection in the receptacle in question or at the previous receptacle or outlet box on the daisy chain back to the panel
Thank you AllanJ
There was no tripped breaker, I was trying to find the breaker that belonged to the circuit that I want to add a light to. But, I suppose the fact that I switched off the breaker myself might have caused the 'loose connection' to detach itself.
So, my next question would be, how can you track back from that receptacle and find the line of items on that circuit, through the walls?
I wanted to remove this post, because I did the 'quote' thing wrong but I can't find where the remove button is. :whistling2:newbie's what can you do with them?
lovetobuild 02-11-2011 10:05 AM
Thank you AllanJ
