Receptacle Spacing On 42" Bar Height Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 10:12 AM   #1
Receptacle spacing on 42" bar height wall
I couldn't find anything in code to address this situation. In the kitchen we will have a 42" high wall that is open to the dining room with a 12" overhanging counter into the dining room. This is the wall with our slide-in range on it and there is about 6" of backsplash. It is the right-hand side of a U-shaped kitchen. From the back wall up to the range is 36". Do I need to have a receptacle in this area since it is larger than 24"? Since it is similar to a penninsula, do different rules apply? I wasn't planning on a receptacle here at counter level, only one lower in the wall for the range.
kidsncats is offline   Reply With Quote
Old 02-21-2012, 10:53 AM   #2
Licensed electrician
Rewards Points: 1,600
Can you post a sketch? If the countertop is more than 12" wide you need to meet the 2'/4' spacing requirements for receptacles.
Old 02-21-2012, 11:18 AM   #3
I'm hoping the pic loads. It's definitely more than 12" i'm talking about, but since the wall behind the range countertop is only 6" high, I though differnet rules might apply.
[/IMG]
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
they poured the back foundation wall to the wrong height. Now..... CumminsTruck Building & Construction 14 06-29-2009 11:24 PM
