Old 01-03-2009, 07:06 PM   #1
Receptacle screw terminals
For the newer receptacles that uses metal screws, are you supposed to loop the copper wire around the screw or just sit it straight? for the cooper GFI there was a hole and then the screw clamp comes down and it was very clear, for the regular cooper the strip gauge seems a little short for the wire to loop around the screws?
I always loop the ground wire though.
DIYGST is offline   Reply With Quote
Old 01-03-2009, 07:24 PM   #2
Custom Cabinet Maker
LOOP in the PROPER direction :}
skymaster is offline   Reply With Quote
Old 01-03-2009, 07:26 PM   #3
The loop should wrap CW so that as the screw tightens, the wire will tighten around the screw.
Old 01-03-2009, 07:27 PM   #4
Electrician's Helper
Pudge565's Avatar
Send a message via AIM to Pudge565
Strip gauge is probably only for the push in connection.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Old 01-03-2009, 08:34 PM   #5
Licensed Pro
For GFCI's and receptacles with the screwdown clamps, just strip the wire according to the gage, insert in the hole, and tighten the screw. No looping necessary.
Receptacle Rating question KE2KB Electrical 19 12-20-2008 07:20 PM
Receptacle Rating question KE2KB Electrical 5 12-18-2008 06:36 PM
Wiring around screw terminals daxinarian Electrical 3 07-14-2008 05:41 PM
Wago terminals for residential line-voltage connections BigJimmy Electrical 3 05-22-2008 02:27 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 10:28 AM
