-   -   Receptacle screw terminals (http://www.diychatroom.com/f18/receptacle-screw-terminals-35015/)
DIYGST 01-03-2009 06:06 PM
For the newer receptacles that uses metal screws, are you supposed to loop the copper wire around the screw or just sit it straight? for the cooper GFI there was a hole and then the screw clamp comes down and it was very clear, for the regular cooper the strip gauge seems a little short for the wire to loop around the screws?
I always loop the ground wire though.
skymaster 01-03-2009 06:24 PM
LOOP in the PROPER direction :} :yes:
Just Bill 01-03-2009 06:26 PM
The loop should wrap CW so that as the screw tightens, the wire will tighten around the screw.
Pudge565 01-03-2009 06:27 PM
Strip gauge is probably only for the push in connection.
HouseHelper 01-03-2009 07:34 PM
For GFCI's and receptacles with the screwdown clamps, just strip the wire according to the gage, insert in the hole, and tighten the screw. No looping necessary.
