Receptacle Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 05:45 AM   #16
Rewards Points: 506
I think I took the bait on this thread...anyone else feel this way?
jlmran is offline   Reply With Quote
Old 03-29-2011, 06:36 AM   #17
Originally Posted by frenchelectrican View Post
Did you try to change the battery on the DVM { digtal volt meter } ?? some case weak battery can give you a werid reading signal so try swap the battery or use diffrent voltmeter ?
and turn off any 240 volts load like water heater or stove or dryer that.
At the same time call the POCO to come out and have them check out their end first if they say good on thier side then it will be wise move to call in Electrician to come on and deal with loose netural connections.
Merci.
Marc
ok i will do all the things you guys have mentioned i appreciate the help
d4nieL is offline   Reply With Quote
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 08:59 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 10:58 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
