Receptacle Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 08:42 PM   #1
Receptacle Question
I have a house that only has the neutral and positive wire in the receptacles I was told that in order to change the receptacle to newer ones with ground that the best method is to ground it to the metal case is this right?
My second question is when I test the outlets before and after I am getting about 178, 180 volts coming from them this is my biggest concern why am I getting more than what I should be from the outlets?
d4nieL is offline   Reply With Quote
Old 03-28-2011, 08:47 PM   #2
Electrical Contractor
kbsparky's Avatar
What kind of tester are you using? IT sounds like you have a peak-sine wave voltage tester there ...
-KB
Old 03-28-2011, 08:51 PM   #3
im using a voltmeter set on 200 AC i think
Old 03-28-2011, 08:58 PM   #4
Rewards Points: 506
Bonding the receptacle to the metal box is only useful if the box is also bonded correctly.
Regarding goofy voltage...what do you mean when you say testing "before and after"?
jlmran is offline   Reply With Quote
Old 03-28-2011, 09:34 PM   #5
I mean before I changed the outlet to a newer grounded outlet and after. I also checked some of the outlets untouched in the house and they are all reading about 180 volts, any idea why? is this dangerous?
Old 03-28-2011, 09:42 PM   #6
Rewards Points: 506
If your readings are accurate I would contact an electrician or the power company...quickly.
Old 03-28-2011, 09:48 PM   #7
explination? i mean what could be causing this?
Old 03-28-2011, 09:55 PM   #8
Rewards Points: 506
A loose connection on the neutral conductor. If this connection is loose, there potentially could be damage imposed on devices attached to the various circuits.
Old 03-28-2011, 10:30 PM   #9
could having some of the outlets positive and neutral reversed cause this? because in changing some of the outlets I did find that some of them were reversed for some reason. I also noticed some are daisy chained? there are 2 positives and 2 neutrals?
Old 03-28-2011, 10:30 PM   #10
If the readings are correct I would immediately unplug any electronic device you would like to still work in the future. Are you having any other weird things happening electrically speaking? Also just because the outlet is self grounding doesn't mean you have a valid ground.
clydesdale is offline   Reply With Quote
Old 03-28-2011, 10:38 PM   #11
Rewards Points: 506
No. Reversing terminals does not affect voltage.
Old 03-28-2011, 10:39 PM   #12
there is nothing plugged into the outlets the house is empty. I havnt really noticed any other problems although i did have an air purifier plugged in that i noticed either voltage spikes or drops like it would cut out for a second.
Old 03-28-2011, 10:53 PM   #13
Rewards Points: 22
change the battery in the volt meter. i have seen weak batteries give erratic results. also use the meter in another building and see what you get. as mentioned earlier a bad neutral can give numbers like you have. if these are true numbers, call power co asap.
bernie963 is offline   Reply With Quote
Old 03-28-2011, 10:59 PM   #14
" Euro " electrician
frenchelectrican's Avatar
Did you try to change the battery on the DVM { digtal volt meter } ?? some case weak battery can give you a werid reading signal so try swap the battery or use diffrent voltmeter ?
and turn off any 240 volts load like water heater or stove or dryer that.
At the same time call the POCO to come out and have them check out their end first if they say good on thier side then it will be wise move to call in Electrician to come on and deal with loose netural connections.
Merci.
Marc
Old 03-29-2011, 06:42 AM   #15
Rewards Points: 506
Originally Posted by alyna
The L indicates that it is a lock type receptacle, so the face is circular with 3 openings in a concentric shape
Concentric is not a shape, it is a condition or circumstance.
changing 3 prong receptacle to 4 prong WendyS Electrical 12 01-17-2010 09:59 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 07:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 06:36 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
