Receptacle "at The Panel" - Electrical - DIY Chatroom Home Improvement Forum
Old 06-17-2012, 09:27 PM   #1
kevinp22's Avatar
Receptacle "at the panel"
I am having a new 200 amp panel installed tomorrow and as part of their standard panel install, they will be adding a single GFCI duplex receptacle "at the panel"
if appears that this is common practice. My question is whether this receptacle needs to be on its own circuit, or, later, I can tie it into one of my existing GFCI circuits (plenty of room, only 4 receptacles and 3 lights on it). I really dont need a dedicated circuit receptacle there but will keep it so if required.
Kevin
kevinp22 is offline   Reply With Quote
Old 06-17-2012, 10:46 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Maybe. Depends on what the other circuit serves.
Why bother? With a new panel you should have plenty of bresker space.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-17-2012, 11:04 PM   #3
kevinp22's Avatar
I suppose you are right. The EC was probably thinking, why does a 1500 square foot house need a 42 space panel. I am trying to future proof - what if we someday have electric water heater, 2 electric cars, etc.
I suppose one circuit in the scheme of things is pretty insignificant
Old 06-17-2012, 11:18 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Do whatever you want, I only install this receptacle at the panel to meet the satisfaction of 210.52 (G)
The Following User Says Thank You to stickboy1375 For This Useful Post:
kevinp22 (06-18-2012)
Old 06-18-2012, 07:01 AM   #5
Rewards Points: 166
Kevin
The less expensive way for a "sparky" to satisfy the requirement that a basement needs a receptacle is to attach it to the panel. After mine was done, I used that panel GFCI to start branching out. Even though I couldnt get the radius perfected on that EMT.
Receptacle "at the panel"-copy-2-100_7790.jpg   Receptacle "at the panel"-100_8070.jpg
Minus08 is offline   Reply With Quote
The Following User Says Thank You to Minus08 For This Useful Post:
Old 06-18-2012, 08:54 AM   #6
Rewards Points: 6,652
I have one at the panel, due to that is where my networking equipment sits, and my Ted5000 plugs in. It covers the basic need of an outlet in the basement.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 06-18-2012, 12:00 PM   #7
Minus08 did the inspector pass your panel wish the other wires comming in from the top.. my inspector said no wires other than the main 200 amp wires are allowed to be in that space ???? just a question
chessy is offline   Reply With Quote
Old 06-18-2012, 12:07 PM   #8
A "Handy Husband"
rjniles's Avatar
Must be a local amendment as it is not NEC. (Or an inspector is making things up.)
Old 06-18-2012, 12:15 PM   #9
in ontario canada rule6-212, 12- 3034
branch circuits condutors may not enter this section . only service conductors and the service ground conductor may enter this section
RJniles...after you said no i had to look it up... my inspector is being a little crazy but it is YES SIR all the way.. coming back this week for final...
Old 06-18-2012, 01:20 PM   #10
Rewards Points: 166
Yes. There's a green approved sticker on the inside of the panel door.
Old 06-18-2012, 01:25 PM   #11
Canuck rule.
Old 06-18-2012, 01:26 PM   #12
That is because Canada feels that people should not be up where main power enters. Why who knows, but most of us can guess which idiot made that rule.
Old 06-18-2012, 03:04 PM   #13
A "Handy Husband"
rjniles's Avatar
If you updated your profile to show your location, we would not give answers based on the NEC when the CEC applies. Not trying to be ugly but the location of the poster helps get better answers.
Old 06-18-2012, 04:29 PM   #14
thanks RJniles... done .. updated my profile...
Old 06-18-2012, 04:52 PM   #15
A "Handy Husband"
rjniles's Avatar
I don't think we can blame George Bush
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 02:18 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 01:07 AM
Welder Receptacle - What Electrical Box SNAFU Electrical 4 10-26-2010 10:45 PM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 02:04 AM
