Receptacle In Medicine Cabinet: Code Compliant? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2013, 01:40 PM   #1
Receptacle in Medicine Cabinet: Code Compliant?
As part of a bathroom renovation, Id like to install a recessed medicine cabinet and add to its interior a duplex receptacle for electric toothbrushes. There will be a second duplex receptacle located on the wall above a 24-inch vanity.
One general contractor told me that adding the receptacle wouldnt be a problem; another said that this wouldn't be code compliant. Whos correct? I cant find anything in the 2010 California Electrical Code (its based on the 2008 NEC) that supports either claim. If a duplex receptacle cannot be located within a medicine cabinet, would you kindly: 1) point me to the proper code provision, and 2) explain the difference between that what Im proposing, and a prefabricated medicine cabinet that has built-in receptacles.
For reference, the 2010 California code is here:
https://bulk.resource.org/codes.gov/bsc.ca.gov/
Thanks for your opinions. I appreciate them.
bpSF is offline   Reply With Quote
Old 08-31-2013, 01:42 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
There is no issue with installing a receptacle inside a cabinet, BUT... this receptacle cannot replace the required bathroom receptacle.
The Following User Says Thank You to stickboy1375 For This Useful Post:
bpSF (08-31-2013)
Old 08-31-2013, 01:43 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would say it is OK as long as it is GFI protected and on a 20A bathroom receptacle circuit.
The Following User Says Thank You to k_buz For This Useful Post:
bpSF (08-31-2013)
Old 08-31-2013, 02:02 PM   #4
Does every question posted here receive such prompt responses? I'm amazed.
@stickboy1375: The receptacle in the medicine cabinet would be in addition to the minimum number of receptacles required by code.
@k_buz: It would be GFIC protected and on a proper circuit. I'll hire a licensed electrician to be sure of it.
Thanks for your replies.
Old 08-31-2013, 02:05 PM   #5
E2 Electrician
I get this request all the time, people like having their electric toothbrush out of sight....
Old 08-31-2013, 05:13 PM   #6
Bill Kearney
Rewards Points: 1,174
Trouble is there' not usually enough room for the base of a lot of chargers, nor height for the gizmo without losing all the other shelves.
Robern sells cabinets with outlets like this in them.
wkearney99 is offline   Reply With Quote
Tags
medicine cabinet , nec , receptacle
Wiring old medicine cabinet with fluorescent lighting okieopie Electrical 9 05-11-2015 09:51 AM
Overhead Sconces For Medicine Cabinet jdbs3 Electrical 0 06-25-2012 03:24 PM
medicine cabinet question farmallih1466 Kitchen & Bath Remodeling 3 01-17-2011 09:32 PM
Is this kitchen remodel code compliant? jheavner Electrical 18 10-07-2008 11:01 AM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
