Receptacle Install Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 10:51 PM   #1
Rewards Points: 672
Receptacle Install problem
I am replacing a wall electrical receptacle. The problem that I am having is the wallboard on the top and the bottom of the box has "broken" away so that the "ears" on the top and the bottom of the new receptacle have nothing to back up to when screwing it into the box so the outlet goes too far back into the box. Does anyone have tips on how I correct this issue? Thanks!
kennykenny is offline   Reply With Quote
Old 03-17-2011, 11:56 PM   #2
Rewards Points: 330
they make plastic spacers.they come in strips.home depot,lowes.
oleguy74 is offline   Reply With Quote
Old 03-18-2011, 01:01 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there is also a piece of tin that fits behind the recep and lays against the wall. Don't like those so I won't even find a picture of one.
Solid copper wire wrapped around a phillips screwdriver and then cut to the proper length works real well too.
Old 03-18-2011, 01:04 PM   #4
Licensed electrician
Rewards Points: 1,766
Nap, instead of the metal ones try these.
http://www.arlcatalog.com/Miscellane...0Extenders.htm
Old 03-18-2011, 01:14 PM   #5
nap
You talking to me?
nap's Avatar
Not those. Those are box extenders. I was talking about a C shaped plate that sets flat against the wall and behind the device to support the device. They have never worked well for me.
Well, I can't even find a picture quickly.
but yes, for box extenders, I definitely prefer the plastic ones. Had some, uh, not so happy times with the metal ones.
here they are:
http://www.erico.com/products/CADDYcfcDvcLvlrRetnr.asp
Old 03-18-2011, 05:40 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
here they are:
I have never like the metals ones you are talking about.
They just seem to small for me, not much bigger than the receptacle.
Switched Receptacle Question MrBill_DIY Electrical 3 11-21-2010 10:07 PM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Under sink filtration install problem? Water comes out faucet side when disposal on sprtfan Plumbing 16 08-17-2010 10:13 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
