Old 07-09-2011, 05:48 PM   #1
Receptacle help!
I am currently replacing the receptacles in my home. Built in late 60s. Two of the wall receptacles are without power. I checked the main breakers and they are fine. The other receptacle in the room are working just fine. What do I do now? I've rewired the receptacles over and over and still no power. HELP PLEASE
victor86 is offline   Reply With Quote
Old 07-09-2011, 07:08 PM   #2
Receptacle help!
The feed to these outlets have been interrupted. You need to know everything that is on this circuit and trace the issue from the panel outward. It could be as simple as a broken wire.
You should look to the components on each side of the outlets as starting points.
Ron
B. Franklin 1759
Old 07-09-2011, 07:43 PM   #3
Receptacle help!
So do I open the panel box? Or check out the box on the attic? I apologize but im really bad with electrical terms
Old 07-09-2011, 07:47 PM   #4
Receptacle help!
Did these outlets work before you changed them? If yes, look for what you may have miswired or disconnected. Is there a GFCI that could be tripped? Are the circuit breakers all ok?
____________
Vince
Old 07-09-2011, 07:52 PM   #5
Receptacle help!
Yes they did work, they were old two hole receptacle. The wiring I have tried various ways of wiring them and still no power. The other two in the room are working just fine.
Old 07-09-2011, 08:56 PM   #6
Semi-Pro Electro-Geek
Receptacle help!
Are you replacing the old 2-prong receptacles with 3-prong receptacles? If so, how are you grounding them?
Some pics of this mysteriously nonfunctional receptacle might help figure out what the wiring problem is.
mpoulton is offline   Reply With Quote
Old 07-09-2011, 09:09 PM   #7
Receptacle help!
Grounding them to the green bolt/nut/not sure of what it's called
Old 07-09-2011, 09:24 PM   #8
Receptacle help!
Yeah, but with what? Does the existing wiring have a good grounding conductor?
Old 07-09-2011, 09:26 PM   #9
Receptacle help!
If there was definately power there before,
Then most likely there is a miswire,
Or possibly old brittle wires have been broken
just by moving them.
Remove the recepticule.
and place a test lamp
on the white and black wires.
Does it light up ?
If it does then it could only be a wrongly wired
recepticule.
Be real carefull,
Always safe !
dmxtothemax is offline   Reply With Quote
Old 07-09-2011, 09:30 PM   #10
Receptacle help!
With a thin copper cable. If anyone has contact with a reliable Electrician here in Greensboro NC it would be much better.
Old 07-09-2011, 11:07 PM   #11
Receptacle help!
This is a simple job. Any local electrician should be able to clear it up in about 1/2 an hour.
If one of your friends or neighbors has a contact, I'd use that. If not, use the local Yellow Pages. Call a couple if your unsure of costs.
Ron
B. Franklin 1759
Old 07-10-2011, 02:41 PM   #12
Tizzer's Avatar
Receptacle help!
You may have screwed yourself by doing that. If you marked each wire to begin with, there was no need to go back and try various ways.
Per chance, is there a switch on the wall where the 'bad' ones are? Try one of these, they don't cost much.
Tizzer is offline   Reply With Quote
Old 07-10-2011, 04:56 PM   #13
Receptacle help!
I don't think the Op should do anything except dial a phone. The lack of any electrical knowledge is pretty obvious and the only thing he can do is injure or kill someone at this point.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
jschaben (07-10-2011)
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 01:07 AM
Switched Receptacle Question MrBill_DIY Electrical 3 11-21-2010 11:07 PM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
Receptacle Rating question KE2KB Electrical 5 12-18-2008 06:36 PM
