Receptacle Box With ONLY Red Wire - Can I Connect A Lamp To It? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 11:13 PM   #1
Receptacle box with ONLY red wire - can I connect a lamp to it?
I opened up a blank wall cover plate and in it there's a red wire going in and coming back out. This receptacle box is 3 feet right above a light switch that turns a different outlet on/off.
Can I connect a wall light fixture to this red wire, or do I always need a ground and a neutral wire as well when connecting a light fixture?
Thanks!
gsur is offline   Reply With Quote
Old 07-23-2012, 11:18 PM   #2
"So I Re-Wired It"
MisterZ's Avatar
First, a pic would help. This sounds like an odd setup.
Second, you need at minimum a hot and neutral. To complete a circuit.
Notice how lights come with two wires.
MisterZ is offline   Reply With Quote
Old 07-23-2012, 11:33 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Old 07-24-2012, 11:56 AM   #4
Rewards Points: 485
One red wire in and one red wire out? Then one of them must be actually a neutral. Just figure out which one (turn the power back on and check for voltage between a known neutral and each of the wires). Make sure the other one is at earth potential (no voltage drop between the wire and a known neutral). Also, tape that one white for later reference.
csab_ is offline   Reply With Quote
yet another 3 wire range hookup question - grounding receptacle plate/box? rkg Electrical 7 04-03-2012 01:02 AM
Wiring nut type for lamp wire and ballast wire. Wek Electrical 3 03-01-2011 01:59 PM
replacing 3 wire to 4 wire compressor fan - please advise! frazwr01 HVAC 2 06-27-2010 10:44 AM
Decommissioning old armored wire circuit toddmanqa Electrical 6 12-04-2009 08:55 AM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
