Receptacle Box Is Not Flush With Drywall - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 10:43 AM   #1
Rewards Points: 159
Receptacle box is not flush with drywall
My house has the blue plastic boxes nailed to studs.
I have a few of them where the stud side is flush with the drywall.
The opposite side has sunk in.
So the receptacle is crooked and is not tight.
What are my options to fix this?
theedudenator is offline   Reply With Quote
Old 11-21-2010, 11:42 AM   #2
I=E/R
a7ecorsair's Avatar
The ears on the top and bottom of the yoke should be contacting the drywall when you snug up the screws. This should stabilize the device.
a7ecorsair is offline   Reply With Quote
Old 11-21-2010, 03:11 PM   #3
Do it right.
sounds like some cull pile lumber
SubSailor is offline   Reply With Quote
Old 11-21-2010, 03:24 PM   #4
iminaquagmire's Avatar
Rewards Points: 338
Use box extenders like these from Arlington:
http://www.arlcatalog.com/Miscellane...0Extenders.htm
iminaquagmire is offline   Reply With Quote
Old 11-22-2010, 02:30 PM   #5
Rewards Points: 159
Do they sells these at the big box stores?
That is probably what I need to do.
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 10:05 PM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 02:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
bakerboard and drywall ontheroad1015 Drywall & Plaster 3 02-11-2009 06:17 AM
