Receptacle Box Knockouts?? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 05:44 PM   #1
Question
I just wired a new room I'm building in the basement and may have made a mistake so I need to confirm....
I used metal handy boxes for all the receptacles and switches (couldn't use plastic since I used metal studs). Anyhow, I wired them all through the bottom knockout and not the rear. Am I going to have a problem with the inspection?
Thanks!
MoreBeer is offline   Reply With Quote
Old 05-02-2010, 05:52 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
As long as the box is sizeed for the device and number of wires you are go to go.
jbfan is online now   Reply With Quote
Old 05-02-2010, 05:55 PM   #3
So, there's nothing in the electrical code stating that the rear knockouts must be used with new wiring inside walls?
BTW...thank you for your speedy reply!
Old 05-02-2010, 05:57 PM   #4
jbfan's Avatar
Rewards Points: 382
If the box has a knock out, then it can be used.
Did you use the bushing for the metal studs with the romex?
Old 05-02-2010, 05:59 PM   #5
Yes, I have the plastic inserts within the stud hole openings.
Old 05-02-2010, 06:06 PM   #6
jbfan's Avatar
Rewards Points: 382
One issue I can think of is the handy box.
To me a handy box is large enough for one cable and a device.
Can you take a picture of the boxes you used?
Old 05-02-2010, 06:10 PM   #7
JB....I can take a picture later tonight and post it. Figure about 9:00 PM. Thanks again!
Old 05-02-2010, 06:17 PM   #8
jbfan's Avatar
Rewards Points: 382
This is a handy box.
http://electrical.hardwarestore.com/...ox-238329.aspx
Old 05-02-2010, 06:21 PM   #9
the Musigician
DangerMouse's Avatar
You might want some of these too?
DM
Old 05-02-2010, 06:48 PM   #10
Yes, I have those wire clamps on the boxes.
Actually, my boxes are slightly different...they include a bracket for mounting, etc. Will post pics in about 10 minutes.
Old 05-02-2010, 07:00 PM   #11
Here's some pictures. One of a receptacle on the metal stud and another on the furring strip covered concrete stud of the house foundation. So....will these pass inspection?
Old 05-02-2010, 07:01 PM   #12
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
I may be wrong, but I thought that with metal studs you must use BX and not Romex. I guess with the bushings it makes it ok?
Old 05-02-2010, 07:12 PM   #13
As long as you have the plastic inserts, romex can be used. I do know that much. LOL!
Old 05-02-2010, 07:13 PM   #14
Registered User
Rewards Points: 5,466
Remember to tape your foam board joints and foam board the rim joist....
Be safe, Gary
Old 05-02-2010, 07:26 PM   #15
Master Electrician
Rewards Points: 3,808
I prefer deeper boxes but otherwise looks like a decent install. You may get an anal inspector who will require the romex secured to the side of the stud.
brric is offline   Reply With Quote
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 08:10 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
