Recently Installed 3 Way Switch Stopped Working - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2012, 12:11 PM   #1
rgg
recently installed 3 way switch stopped working
Hi
I replaced a bunch of 30 year old electrical switches in my house a few months ago. One of the switches I replaced, was a 3 way one that needed a lot of force applied to stay in the ON position.
So now the new switch in that same spot has the same issue. The old and new switches are different brands and styles. Could it be a sign of an electrical issue? Or most likely just coincidence?
This switch is next to a door that produces some vibration when being closed. Can this vibration be affecting the switch? Also, this switch is right next to 2 other switches...never had a problem with those.
Thanks!
rgg is offline   Reply With Quote
Old 09-20-2012, 12:24 PM   #2
joed's Avatar
Rewards Points: 11,988
Sounds like another bad switch. I can't think of any electrical issue that cause a switch to go bad.
Old 09-20-2012, 04:34 PM   #3
Oso954's Avatar
Rewards Points: 740
Originally Posted by rgg View Post
Hi
What do you mean by that ?? Is the switch toggle moving out of the on position ?? Or, the handle isn't necessarily moving, but the light may not come on. Then by adding a lot of pressure the light comes on.
If it is the latter, I would look for a loose connection somewhere in the box. I would check every wire nut connection, black, red, or white.
Oso954 is offline   Reply With Quote
Old 09-20-2012, 04:39 PM   #4
rgg
When I apply pressure to the top of the switch, it does change positions, but the light won't turn ON unless I consistently apply more pressure with my finger. The moment I stop pressing, the light goes off again.
This happened with both the 30 years old switch and the replacement one (after a few months)
Old 09-20-2012, 04:41 PM   #5
liscenced electrician
Rewards Points: 538
Sounds like a bad switch. Brand doesn't make any difference
jimmy21 is offline   Reply With Quote
Old 09-20-2012, 06:03 PM   #6
Rewards Points: 150
This is a 3-way? So "on" can be either switch position? Does it happen in both switch positions?
silversport is offline   Reply With Quote
Old 09-21-2012, 11:43 AM   #7
rgg
I replaced the switch and it works fine now (of course). I hope it doesn't happen again in a few months.
Thanks everybody for your input.
VERY EERIE! Remote garge door openers and both car remotes stopped working! proofer Automotive Repairs 16 12-03-2016 09:31 AM
Light switches and outlets stopped working. jeweladdict Electrical 4 08-13-2012 11:51 AM
Light in one lighted three-way switch not working dalepres Electrical 2 06-26-2012 07:27 AM
Light Switch Stopped Working mrwyant Electrical 3 06-04-2012 09:31 AM
Light Stopped Working gershon Electrical 5 01-10-2007 09:03 PM
