Rec Room Wall Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:01 PM   #1
Rec room wall light switch
No matter what I try I cannot seem to get this metal light switchplate to be flush againt the wall. I can always take a pic behind the switchplate if needed. The electrical box might have to be switched out because the screws go in much easier on the top vs on the bottom. There almost isnt anything for the bottom screws to go into so when you try and tighten them one side tightens and the other side doesn't. Sounds confusing I know. I'm not sure how to explain it.
dinosaur1 is offline   Reply With Quote
Old 12-21-2011, 09:25 PM   #2
Rewards Points: 506
How long are the screws? Appears they are bottoming out (or hitting an obstruction) before they reach the surface of the plate.
jlmran is offline   Reply With Quote
Old 12-21-2011, 09:43 PM   #3
The 2x4 was not installed straight and the wall plate will not lay flush on wall.
Sticks out about 1/4 inch on the top right corner.
Old 12-21-2011, 09:46 PM   #4
1/2 screws and there is one 2x4
Old 12-21-2011, 09:47 PM   #5
Rewards Points: 506
So the box protrudes out too far due to stud placement? Fix the stud/box, or hack in some joint compound on the wall surface.
Old 12-21-2011, 09:50 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
The switch plate mounts to the switches and not the box.
If you have trouble getting the bottom scres in, you may have a bad switch.
jbfan is online now   Reply With Quote
Old 12-21-2011, 09:54 PM   #7
Rewards Points: 506
But the leg bone is connected to the ankle bone.
Old 12-21-2011, 10:15 PM   #8
Should I also switch to a different wall plate? I have a metal one now. Does it matter?
Old 12-21-2011, 10:30 PM   #9
Electrician
SD515's Avatar
Rewards Points: 504
Changing the plate isn’t going to matter if the box is sticking out of the wall, or the switches aren’t fully seated on the box/wall.
Kyle
Old 12-21-2011, 10:33 PM   #10
I guess I'm asking whats the best type of plate to use. What's the norm for a Rec room? Plastic, metal, etc.....
Old 12-21-2011, 10:40 PM   #11
Electrician
SD515's Avatar
Rewards Points: 504
Personal preference. Metal if high abuse is a good idea. i.e. kids rec room.
Kyle
Old 12-21-2011, 10:41 PM   #12
Yep...kid's
Old 12-21-2011, 10:57 PM   #13
Rewards Points: 282
if you use metal plates, please be certain that the switches are in fact properly grounded....very often they are not in residential (ok if plastic plates and plastic screws used, just not best practice).
(and remember that if the metal box is the ground, remove the insulators from the switch screws! that mistake is often made also when people "update")
jcrack_corn is offline   Reply With Quote
Old 12-22-2011, 04:03 AM   #14
dmxtothemax's Avatar
Rewards Points: 5,346
Perhaps the box is not deep enough for the switchs and all the wires to,
Try moving the wires around,
so they lay flater,
or move them to the side,
rather than behind the switchs.
dmxtothemax is offline   Reply With Quote
Old 12-22-2011, 06:18 AM   #15
jbfan's Avatar
Rewards Points: 478
I use unbreakable nylon covers.
room will not light up with switch bigflem38 Electrical 4 07-12-2011 04:36 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Wall outlets stay charged even when light switch is turned off proofer Electrical 33 01-25-2008 04:43 PM
