Reason For Not Burying A Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 07:44 PM   #1
Ummmm...
Shpigford's Avatar
Question
Reason for not burying a switch?
We've got a light switch that previously went to a set of sconces. We removed the sconces (just don't want them anymore), and so we've got a switch that goes to nothing.
I know that code says not to bury the switch, but I'm curious why?
Sure, if someone in the future wanted to put something back there that'd be convenient for them...but let's assume no ever needed any use out of that switch for anything at all.
Is there some safety reason? Or is it just convenience? Something else?
Shpigford is offline   Reply With Quote
Old 05-27-2012, 08:17 PM   #2
Code05's Avatar
Rewards Points: 1,104
If you wish to get rid of the box, simply disconnect the feed wires from the source where they get power.
Assuming there are no others wires and connections in said box, correct?
Code05 is offline   Reply With Quote
Old 05-27-2012, 08:19 PM   #3
Ummmm...
Shpigford's Avatar
That's my assumption...and that's a good solution.
But I'm still curious why I keep reading "Don't bury the box, don't bury the box"...just haven't read why people keep saying that.
Old 05-27-2012, 08:21 PM   #4
Lavid2002's Avatar
Rewards Points: 85
If people need to service the conection later for diagnostics or troubles one shouldn't be expected to find a buried box behind drywall. Get rid of the wiring going to the box or put a cap over it. Hiding a wire junction is a poor choice for the above reasons.
Lavid2002 is offline   Reply With Quote
The Following User Says Thank You to Lavid2002 For This Useful Post:
Shpigford (05-27-2012)
Old 05-27-2012, 08:22 PM   #5
Licensed electrician
Rewards Points: 1,876
The code requires any energized connections to be accessible so they cannot be buried. It also makes troubleshooting a real pain.
Old 05-27-2012, 08:31 PM   #6
Mainly its because a connection in the box may come loose and something that is fed from the box, won't work! In order to make repair the electrician will have no idea that the box exists or where it may be.
Also, insulation in the cable feeding the box can fail and cause a short that trips the breaker or even start a fire.
If you must bury the box, do as others have stated and disconnect the feed wire at its source.
Then you can do what ever you please without concern for future problems.
The Following User Says Thank You to Wildie For This Useful Post:
Old 05-28-2012, 10:28 AM   #7
Rewards Points: 240
Remove switch, twist wire nuts on the wires, and install a blank cover plate of your choice.
Old 05-28-2012, 10:36 AM   #8
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If that is the only way to turn on a light in that room, you may be violating code by removing the sconces and switch.
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 07:23 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
