#1 |
Tool Geek
Is this really Safe?
Pic off the Net
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & Stay Safe .....Bob Lavery |
#2 |
Licensed Electrical Cont.
Oh please. Not this again.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#3 |
That picture proves some evolutionist's theory about a specie's eventual, natural elimination of the unfittest. This one reminds me of the guy who tied ram jets to a Chevy and could not stop it. Or, the guy that strapped balloons to a lawn chair and rose to 10,000 feet.
#4 |
I don't see any Code Violations in the pool setup lol
But if you go on Vacation and live in the north turn off your water lines or protect them somehow.Another old pic
#5 |
It was a dark and stormy
Is the pool water grounded other than by the cable?
#6 |
Not very safe at all. Those beers should be protected in some type of carrier. There's a good chance one could tip over.
#7 |
As bad as that looks, I'm not sure they're in much danger. You won't find me testing my theory though
![]() Anyone see it as well? Let's forget the fact there's a surge strip and pretend it's just a regular extension cord. If there's any short I think the electricity would jump to the ground wire and trip the breaker, having no or extremely little impact on the people inside. Like applying electricity to the hood of a car where the power touches one side of the hood and the ground touches the other meanwhile you're sitting inside it touching the metal as well. It's got rubber tires so the electricity isn't going to likely choose to flow through the whole car when it can jump to ground right through the hood, it's going to take the shortest path. Likewise why would the electricity choose to go through these people when there's lesser resistance and shorter distance to just go to ground wire of the cord instead if a short occured. Maybe if they were stepping out of the pool and grabbed onto a metal fence, or if this thing had a metal pool filter that created an easier ground it would go through the water to get to that ground instead of the one of the wire. I think if that's a rubber pool, and there's no other metal in contact with the water and ground (the metal table is safe it is isolated from ground by the rubber pool floor) the shortest and least resistance place it can go is from the power of the cord to the ground of the cord and won't go through the people. Or I don't know what I'm talking bout, I would think the person unplugging that thing in the pool if it's still live likely to be the only in danger if their body creates less resistance vs. the water. I'm not testing my theory
#8 |
Piedomont i think you have a point. let me expand.
there would still be water between the open connection and the ground wire. and that water would be potentialized and therefore the people will too. but your body can take a LOT of potential voltage - just no current. the least resistance path from open circuit to ground wire in this "network" is through the water 1cm away from the ground wire.. so that will take the bulk of the current. but your rest of the "network" will look like a lumped (no pun intended) parallel resistor which will take SOME current too.. albeit small. can you survive it? good luck! ![]() Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen |
#9 |
It's completely safe because it's obviously not plugged in.
#10 |
You talking to me?
well, I have seen a guy drink a glass of water with a neutral conductor in it while holding the bare end of a hot conductor and proved it was hot by shorting it out after drinking the water.
#11 |
tap water 1M to 100M ohm-meter
salt water 0.2 ohm-meter fresh water 1000 ohm-meter human body 5 ohm-meter Not salt water. . . Last edited by Yoyizit; 10-16-2009 at 08:14 PM. |
#12 |
Wire Chewer
I never realized how well water helps electricity conduct to skin until a few days ago.
We were messing around at work and daisy chained about 13 9 volt batteries. (You could swear they were designed for this!) and it came up to about 127 volts. I touched both ends and got a very weak shock. I licked my fingers and YOUTCH! Was similar to a 120v AC shock but not as much, I wonder why though, is DC less painful as it does not alternate? As for the people in the pool, I wonder if they would in fact get shocked or not if the cord was energized in the water. The theory that it would just go straight to ground makes sense. I also wonder what would happen if it was let under water for a while, the pool covered, then a match lit. It would produce hydrogen and oxygen gases. Also I wonder if they at least plugged it into a GFCI outlet. LOL |
#13 | |
Is this really Safe?Quote:
DC 5x less dangerous? |
#14 | |
Wire Chewer
We also have some very nice big batteries in our UPS... I'm not touching those.
#15 |
Residential Contractor
I want to be an electron when I grow up so I can find out the answers to all these questions
| Display Modes | |
| Is it safe to plug in this flourescent fixture? | doofalot | Electrical | 2 | 08-16-2008 02:27 PM |
| Freestanding/portable safe home heaters?? | sugarmama | HVAC | 5 | 10-30-2007 09:23 PM |
| safe way to add extension to power cord | sil | Electrical | 7 | 10-18-2007 10:58 PM |
| Help Me.....installing Wall Safe | shaw | Carpentry | 7 | 10-01-2006 05:50 PM |
| Gun Safe vs. Floor Joists | allen1466 | Building & Construction | 9 | 03-03-2006 09:16 AM |
