Ready To Admit Im An Idiot -Torque Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 02:28 PM   #1
Rewards Points: 77
Ready to admit im an idiot -Torque question
Ok, reading the specs on my new 200 Amp QO panel. Main lugs using 4-0 Al torque to 250 lb-in which to me converts to 20 lb-ft which seems like nothing. What am I doing wrong????
Mikenra is offline   Reply With Quote
Old 01-28-2012, 02:32 PM   #2
joed's Avatar
Rewards Points: 13,728
You are correct divide by 12 for in-lb to ft-lb.
Old 01-28-2012, 02:49 PM   #3
Rewards Points: 77
So 20 ft lbs sounds right for 4-0 Al?
Old 01-28-2012, 05:18 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
A little no lox on the wires and a 3/8 ratchet has always gotten the job done for me anyway
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-28-2012, 05:22 PM   #5
Rewards Points: 77
I hear ya. I guess my concern is more the meter pan that I can't easily re-torque in the future
Old 01-28-2012, 05:36 PM   #6
plummen's Avatar
Id say youll be safe cranking them down with the 3/8 ratchet
Old 01-28-2012, 06:17 PM   #7
Licensed electrician
Rewards Points: 1,876
Before I started using the proper tool I bet most of my connections were too tight based on the number of threads showing vs when using a torque wrench. Too tight is just as bad as too loose. Follow the instructions and use the proper torque.
Billy_Bob (01-29-2012)
A torque question wavebuy1 Automotive Repairs 3 09-28-2007 03:17 PM
Ready to lay laminate... Question... KUIPORNG Flooring 6 04-13-2007 02:17 PM
Getting ready to tile bathroom floor, question J187 Flooring 4 06-06-2006 12:31 PM
