Reading Backfeed Voltages - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2015, 10:34 AM   #1
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Reading backfeed voltages
No too long back I brought up reading a backfeed voltage through a residential utility meter. When the meter is set and only one leg is hot to it, you'll read full voltage in the other leg. Generally 1 or 2 volts less.
Here's a picture of a conventional meter back, the coil is connected between legs to generate flux to propel the disc. So, once you hook up one leg, its voltage is induced onto the other. A leg to leg check will read near zero. Also, an electronic meter behaves the same way in regards to backfeed.
clw1963 is offline   Reply With Quote
The Following User Says Thank You to clw1963 For This Useful Post:
Jump-start (01-21-2015)
Old 01-21-2015, 10:39 AM   #2
Rewards Points: 1,832
Thank you for the post. This is the reason why anyone trouble shooting should check line to line.
Similar that goes along with this is an open leg while the hot water heater is running or electric heat. Anything that's line to line. The live leg will back feed the other leg. If the 240 volt load is large enough it can get 120 volt lights/appliances running.
Can get very confusing not checking between hots.
Jump-start is offline   Reply With Quote
The Following User Says Thank You to Jump-start For This Useful Post:
clw1963 (01-21-2015)
Wiring Generator to Backfeed Breakers - Neutral and Ground Wires? tjnoff Electrical 84 12-09-2014 08:59 PM
Humidity Reading Jerry8C HVAC 11 11-11-2011 03:36 PM
VisionPro Outdoor Sensor Reading inaccurate bstone17901 HVAC 20 10-12-2011 06:59 AM
Reading glasses mwpiper Safety 24 09-06-2011 10:33 AM
Phantom voltage reading on switch loops jamiedolan Electrical 5 02-09-2009 04:22 PM
