Reading 75 Volts Hot To Ground With Switch Off - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2012, 07:20 PM   #1
Do it right.
Reading 75 volts hot to ground with switch off
Title says it all. It's a ceiling light fixture. Any ideas?
SubSailor is offline   Reply With Quote
Old 10-24-2012, 07:22 PM   #2
Rewards Points: 14,312
What were you doing that caused you to find this out?
Old 10-24-2012, 07:26 PM   #3
Do it right.
Replacing a light fixture, I put my cheapy greenlee voltage detector up to it and it beeped with the switch off so I pulled out my multimeter and read that.
Old 10-24-2012, 07:28 PM   #4
How many wires coming into the box?
Old 10-24-2012, 07:29 PM   #5
Do it right.
3, hot, neutral, ground.
Edit: 1 piece of NMC in case you thought I meant otherwise.
Old 10-24-2012, 08:04 PM   #6
Electrical Contractor
kbsparky's Avatar
How many BULBS were in that fixture when you took that reading?
Install some bulbs in there, and read your voltage again. Betcha you get a reading of -0-
-KB
Old 10-24-2012, 08:11 PM   #7
Do it right.
I had the fixture removed, I just installed the new fixture, lemme check.
Old 10-24-2012, 08:17 PM   #8
Do it right.
KbSparky, I just checked it at the switch, it read 14 volts, but this is a lighted switch so maybe that has something to do with it not reading 0?
Old 10-24-2012, 09:09 PM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,990
That's why. The lighted switch relies on leakage of a small current (a couple milliamps) through the switch when it's off to power the light in the switch. So it's never really truly "off".
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Can someone tell me why my low voltage lights are reading high current at the switch? kmc Electrical 5 06-04-2012 09:38 PM
Timer switch ground wire n0c7 Electrical 6 02-19-2012 08:03 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
switch lacking ground wire anervoustwitch Electrical 17 02-27-2009 04:12 PM
does a switch in an old work box require a ground? jheavner Electrical 7 10-04-2008 11:09 PM
