Re-Wiring In Ontario, Canada - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 12:40 PM   #1
Rewards Points: 22
Re-Wiring in Ontario, Canada
I need to re-wire my kitchen and my contractor want to run wires behind the crown moulding I'm having installed. Is this legal? He may also run some new wire from the electrical panel to the kitchen through return cold air ducts. Legal?
pgs_28 is offline   Reply With Quote
Old 01-24-2011, 01:40 PM   #2
joed's Avatar
Rewards Points: 13,696
Not sure about the crown issue but in the cold air duct is not legal. You can cross the duct but can not use the duct as a chase for the cables. You must have this work done by a licensed electrical contractor not a general contrator or handyman.
Make sure you get an inspection from ESA.
Old 01-24-2011, 01:57 PM   #3
Rewards Points: 22
Does anyone know about crown moulding? Thanks.
Anyone? thanks.
Old 01-24-2011, 05:05 PM   #4
Electrician
Rewards Points: 802
If the cable is supported every 5feet I can't see why it couldn't go in the crown moulding. Just make sure it is not subject to damage when they install the crown moulding as this may effect if it is legal or not. This would be a good question for your inspector.
darren is offline   Reply With Quote
Old 01-24-2011, 05:41 PM   #5
joed's Avatar
I've done some checking it appears that cable behind the crown is probably OK.
Old 01-24-2011, 08:51 PM   #6
Electrician
Rewards Points: 802
Joe I have never thought about it before but what a good place to run cables if your doing a reno and adding crown moulding.
Old 01-24-2011, 09:50 PM   #7
Rewards Points: 22
Wink
Appreciation
Thanks to everyone!!! Paul
Old 01-25-2011, 07:22 AM   #8
Rewards Points: 6,652
Call Mike Holmes. You are in Canada, and get to see Holmes on Homes & Holmes Inspections before the down under's on the same continent get to see them.
Supply power to a garage in Ontario Canada StarGehzer Electrical 7 10-15-2010 12:47 PM
Wiring on exposed wood beams - Ontario Canada djgap Electrical 5 09-29-2010 12:41 PM
Hello from toronto, ontario canada :) 57_Hemi Introductions 2 07-29-2010 06:40 AM
Question about AFCI and Ontario code as well as some other general wiring queries drunken0monkey Electrical 5 06-15-2010 09:49 AM
Above Ground Pool+Deck Electrical Install (Ontario, Canada) hecubus Electrical 5 08-02-2008 01:42 PM
