Re-wire Dual Pole Switch To Single Pole - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 12:57 AM   #1
Re-wire dual pole switch to single pole
OK, I purchased an automatic light switch timer at Home Depot that I want to install on our front outdoor lights for when we are away, the problem is, the switch is only for single pole switches and our front lights are on a dual pole system. The main switch is next to the front door, and the other one is tucked into an unused corner of the garage. Is there a simple way to re-wire the switches to make the switch near the front door a single pole switch so that I can install the timer, and disable the switch in the garage? Thanks!
bujaman is offline   Reply With Quote
Old 05-31-2011, 01:29 AM   #2
Rewards Points: 512
Are you saying that you're able to control the outdoor light from both the front door and the garage? This would be a 3-way switch circuit, and afaik very uncommon in those two locations.
Old 05-31-2011, 03:05 AM   #3
Yes, I can control the lights from both those areas. So it would be a 3-way switch.
Old 05-31-2011, 07:09 AM   #4
Electrical Contractor
kbsparky's Avatar
Simply remove the switch from the garage, and connect the common lead and 1 of the other wires together with a wirenut. Cap off the remaining wire.
At the front door, identify the capped off wire coming from the garage, and cap it off as well. The remaining 2 wires at the front door now only require a single pole switch.
-KB
Tags
automatic timer , dual pole , single pole
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 11:10 AM
wiring a single pole switch with pilot light Peter C Mullett Electrical 1 01-21-2011 08:17 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 11:37 AM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
