Re-use A Service Entrance Cable And Grounding Requirements - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-03-2013, 01:25 PM   #16
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by stickboy1375 View Post
You need to install it regardless, but the funny thing is, most other utilities won't use it... Not everyone is up to speed yet... lol...
Not required for service changes/upgrades unless by local ammendment..
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
CapeCod153 (05-03-2013)
Old 05-03-2013, 03:27 PM   #17
JW
mm11's Avatar
Rewards Points: 592
Originally Posted by CapeCod153 View Post
What is the best way to do this? BTW, the UFER ground wire is AWG 3, so even thicker than I originally thought.
I believe that you can run a bonding jumper, sized in accordance with 250.66 (#4), to the GEC from the UFER ground. Connection has to be made using a listed means- I would use a correctly sized split bolt lug.
Perhaps the inspector would care to comment on this?
mm11 is online now   Reply With Quote
Old 05-04-2013, 11:25 PM   #18
electures's Avatar
Originally Posted by Jim Port View Post
You will also need to provide an intersystem bonding terminal for the phone and cable systems.
Not required on service changes/upgrades unless by local amendment.
The Following 2 Users Say Thank You to electures For This Useful Post:
CapeCod153 (05-05-2013), mm11 (05-05-2013)
Old 05-04-2013, 11:52 PM   #19
electures's Avatar
Originally Posted by mm11 View Post
4) Support cable within 12" of box, and not more than 4 1/2' between supports thereafter.
No more than 30".
Old 05-05-2013, 10:42 PM   #20
Well, I did the upgrade on Friday. Thanks to everyone that responded to this post - it went pretty well for my first time. For any other newbies reading this in the future, here are some of the things I learned/recommend in addition to all else in this thread:
1) For underground service pay for the disconnect. I'm sure it could've been done live but I'm glad I didn't have to worry about dying!
2) For how thick it is, 200 amp SEU cable is not that expensive relative to other cable. I reused some cable that I had (it was in good shape) thinking it would save me a lot of $ but when I saw the l.f. cost at the store it really didn't.
3) the 200amp SEU cable is hard to bend and work with. Plan your route carefully and expect to fight with it if you have some relatively tight angles it needs to follow.
4) make sure you have enough length of cable to allow the internal ground wire to reach the grounding lug. I almost screwed myself with this one thinking it only had to reach the main service panel lugs and the main ground lug was another 5 inches lower.
5) It took me 5 hrs after pulling the meter to do the following:
*remount the meter pan over the new siding,
*remove the exsting 100amp service cable,
*drill the hole bigger for the thicker 200amp service cable,
*remove the 100amp service panel (disconnect 12 breakers),
*move into place the new 200 amp service panel, increase the holes and *install 2" cable locks on the meter pan and service panel,
*run the 200amp service wire to the service panel,
*install the wire into the meter pan and service panel, and finally
*install the ufer ground wire into new service panel
I drove the copper rods into the ground before they disconnected the panel and these went into the ground much easier and faster than I expected (about 15 min for both). I still need to hook up the ground wire to the rods and the water line plus install about 14 circuits in the new panel.
CapeCod153 is offline   Reply With Quote
Old 05-05-2013, 11:14 PM   #21
Rewards Points: 506
Any pics?
Installation is the Reverse of Removal.
Old 05-06-2013, 08:54 AM   #22
Originally Posted by sirsparksalot View Post
Any pics?
I was in such a hurry I didn't take the time to grab pics. You gotta love the electric co. They show up at 9am with two big bucket trucks and a service truck, tell me to call them when I'm done anytime before 3pm but show up at 12:30pm anyway and the whole crew just sits there waiting until I finished. efficient as a gov't agency. The crew really was super nice, though.
Old 05-06-2013, 08:58 AM   #23
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Typical M.O. for a line crew, and people wonder why electricity costs so much?
Question on grounding main lug service rizzoa13 Electrical 38 06-22-2012 04:25 PM
cable line grounding amakarevic Electrical 56 05-15-2012 10:22 PM
Service Entrance Main Breaker Revamp sandersdon Electrical 21 11-01-2010 10:39 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
