Re-use Old 220V AL Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 01:30 PM   #1
Rewards Points: 133
re-use old 220V AL wiring
In the house there was an old 100amp panel with a 220V line run off it about 35-45 feet to an outlet. I believe it was on a 30amp breaker. The cable is in good shape, no fraying or damage, but it appears to be cloth jacketed. When the panel was upgraded, it was left disconnected. Would it be safe to re-use this cable?
jimmyfloyd is offline   Reply With Quote
Old 01-04-2012, 01:32 PM   #2
joed's Avatar
Rewards Points: 12,848
Depend on what you want to use it for and if the cable is three or four wire.
Old 01-04-2012, 01:54 PM   #3
Rewards Points: 133
Cable has 3 thick wires. It would be used for an air compressor. In the future I might get a welder, but that's a big if right now, so if it needs to be upgraded at that time, it could be.
wiring 110 instead of 220 electric water heater Master Brian Electrical 14 08-22-2010 04:06 AM
Need help wiring old 220v fan motor HotTommy Electrical 28 02-15-2009 09:15 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
220v wiring bwill Electrical 11 02-27-2008 06:48 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
