Re-routing Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 08:50 PM   #1
Re-routing wires
As part of installing new cabinets I am tearing out a soffit. Inside there are a number of electrical wires - some identifiable, others not. I need to move these wires but there is not enough slack in them to route them inside the wall or ceiling. What are my options? What does code generally require?
iceman536 is offline   Reply With Quote
Old 04-18-2011, 09:09 PM   #2
where do the wires go to? a light in the cabinet?
jmans8666 is offline   Reply With Quote
Old 04-18-2011, 09:13 PM   #3
1 wire to light over kitchen sink (in soffit)
1 wire to main kitchen light.
1 wire to bathroom.
1 wire to dining room light
I can deal with these.
The main problem is 8 wires going to the 2nd floor. No easy way to re route them.
Old 04-18-2011, 09:15 PM   #4
post some pictures that would really help. but maybe a junction box there then run a new wire up to the second floor from the j box would work. but i'm not a pro at this
Old 04-18-2011, 11:59 PM   #5
Scared Electrician
Saturday Cowboy's Avatar
you are allowed to use two boxes and a length of wire to lengthen a circuit, as long as those boxes remain accessible.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-19-2011, 12:58 AM   #6
Seems like an effective solution, albeit a little messy. I could attach the junction boxes on top of the cabinets, hidden by the crown molding. My question is where the wires go in/out of the wall and into the junction box do they need to run thru conduit?
Old 04-19-2011, 07:08 AM   #7
Licensed electrician
Rewards Points: 1,634
The boxes cannot be buried or hidden behind the building finishes. They need to remain accessible. Behind an access panel is fine, behind drywall or trim is not.
Old 04-19-2011, 10:12 AM   #8
mem
Rewards Points: 156
You could mount the J boxes flush to the inside top or back of the cabinet to keep them accessible. Although they won't be seen 99% of the time, a blank cover matching the interior of the cabinet would render them practically invisible.
mem is offline   Reply With Quote
Old 04-19-2011, 10:44 AM   #9
I think exposed wire needs to be in conduit
Old 04-19-2011, 11:44 AM   #10
mem
Rewards Points: 156
Probably not imaging the situation correctly--some pictures would certainly help to clarify things. I thought, because iceman was removing the soffit, taller cabinets were going in. Regardless, using the back of the cabinet would allow the cabling to remain in the wall cavity.
Old 04-19-2011, 05:40 PM   #11
Scared Electrician
yeah the wiring needs to remain in the wall
Old 04-20-2011, 12:30 AM   #12
The wiring is currently not in the wall!
Old 04-20-2011, 12:36 AM   #13
One option I am considering is using junction boxes and mounting them on top of the cabinet. They will be hidden from view by the crown molding and will be accessible because the crown will be 8" from the ceiling.
Old 04-20-2011, 06:38 AM   #14
I think the junction boxes need to be accessible. With this idea would they be accessible
Old 04-20-2011, 07:56 AM   #15
mem
Rewards Points: 156
To meet code, I believe you'll need to reroute the wiring inside the wall and mount the boxes in the wall, or on the wall with the cabling entering/exiting the rear of the box.
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 12:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 02:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 01:35 PM
