Re-Route Ceiling Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 02:23 PM   #1
We are eliminating the old dropped drywall ceiling in the kitchen. The ceiling framing is 2x12s (supporting the 2nd floor) and 2x6s that had created the drop ceiling originally. The photo shows how the 2x6 rests (not nailed) on edge under the 2x12 -- but the 2x6 is framing is NOT structural. The 2x6 will stay but the new drywall will cover it.
My problem (see photo) is the Romex which was fed through the 2x6. It has to be re-routed upward into the 2x12 to allow for the new (higher) drywall celing. The wire runs completely across the new recessed area in the ceiling and there is no slack in it. The garage is on the other side of that wall and the Romex plus other wires seem to be bundled and dropped into the main service panel at the far end.
What is the best way to re-route this wire?
CallMeVilla is offline   Reply With Quote
Old 08-10-2011, 02:45 PM   #2
Rewards Points: 6,652
Either run all new romex, or back pull the existing and pull back through new holes in the 2x12 joists.
Tags
re-route electrical
Ceiling fan: can't figure out some wire connections seeeker Electrical 5 06-26-2010 01:28 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Can I run speaker wire in conduit in ceiling Leah Frances Electrical 17 01-15-2009 12:16 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Open beam ceiling and running wire... Alan Electrical 2 12-10-2006 09:14 PM
