Re: Receptacle Replacement - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 10:46 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 484
Usually you can't... I think if you install a GFCI outlet on an AFCI circuit they'd either trip each other or the maybe the GFCI alters the signal somehow that makes the AFCI not work right.. I don't know for sure why or what happens but AFCI instructions will say that you can't install GFCI on a circuit with AFCI protection.
Not a problem at all to install a gfci on an afci circuit!
Gramps, you can either change back to a 2 prong receptacle with no problem, change to a gfci receptacle that offers personnel protection, but no protection for equipment, or find a way to get a ground wire from the panel to each 3 prong receptacle.
Good luck!
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
gramps416 (07-08-2011)
Old 07-02-2011, 11:15 AM   #17
Rewards Points: 150
thanks you guys.
this has been very informative
I think i will change back to the two prong for now,
and maybe later on, see if it is possible to pull more slack to get the ground into the box for all the missing cables in each box. but not to make the last section of cable to taught in the wall. I remember reading somewhere in the past that it is dangerous for the cable to be taught because there needs to be an allowance for movement during different seasons.
If i can't get the cable's pulled, maybe it is a good idea to get one "ground" cable that serves all of the areas, and run it through the attic.
thanks again
-gramps
gramps416 is offline   Reply With Quote
Old 07-08-2011, 02:46 PM   #18
Rewards Points: 150
re: troubleshooting. one outlet does not work. please help
On the advice I revived here, I installed 2 slim profile GFCIs
one functions properly, tested with reset switch.
the other one does not reset, the "light" is on, which is good (see pic attached). this is the outlet that has another load on it. so there are 4 wires in the box (two hot, two neutral). other problems.....
  • it is very "tight" inside, and difficult to shove in all the wires. the left side is sticking out. I tried moving the wires around,but it was difficult and I could not do it after 2 attempts
  • outlet does not work
  • the light switch beside the tv does not work. I don't know if it is downstream or upstream
  • when the circuit breaker was turned on after the work, i used a radio to test the circuit. the radio worked for a fraction of a second and went out
Please let me know what you think is going on. this is a bit frustrating. Is there any reason for concern at the moment? could my GFCI be defective? it is a slim leviton GFCI]
Could the line and load be reversed???
Old 07-08-2011, 04:42 PM   #19
Licensed electrician
Rewards Points: 1,622
The first thing I would check is to make sure the proper pairs of wires are matched in the line and load terminals. Both conductors from the cable need to end up on the same end of the device. They cannot cross between cables.
Pull the device out of the box and see if it resets. You may have inadvertent contact when stuffed into the box.
Old 07-08-2011, 05:11 PM   #20
Rewards Points: 150
ok. just checked. line and load wires are not mis-matched. one cable goes to line, the other to load. as far as which cable goes to line, and which goes to load, when I disconnected the old receptacle, i only did one cable at a time to try to not let a mis match happen, I assumed that the previous wiring had the load on the top, and line in the bottom like the device i have. Maybe standards were different in the late 50s about how GFCI were made.
device is now no longer seated in box.
button still does not reset.
was it possible that the line and load cables are switched?
what is the next test? is there a concern about difficulty moving unit back in box?
Old 07-08-2011, 05:15 PM   #21
Electrician
SD515's Avatar
Rewards Points: 504
Yes the line and load could be switched. Try switching them, see if it resets.
Kyle
Old 07-08-2011, 06:14 PM   #22
Rewards Points: 150
that was it! line and load were reversed.
thanks
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 08:32 AM
low voltage reading at receptacle 2 ball cane Electrical 5 04-06-2011 12:07 AM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 09:52 PM
Electrical receptacle replacement question sherlock Electrical 7 05-20-2005 03:33 PM
