Old 07-27-2014, 09:01 PM   #1
Share |
re: older NMD 60 cable question
i have a wall i wish to insulate with roxul safe and sound. I have some old cable NMD-60 that is hooked up to stove in that wall. (i don't know the gauge off hand). I want to know if i should avoid insulating this area, or is it safe to insulate around NMD-60
Is there something i could do if it is not safe? like maybe putting some PVC pipe around it?
thanks
gramps416 is offline   Reply With Quote
Old 07-27-2014, 10:19 PM   #2
joed's Avatar
You are OK to insulate around it.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 07-27-2014, 11:24 PM   #3
jproffer's Avatar
If you do feel the need to put something "around" it (not sure how you'd get it around it), please please PLEASE don't use regular white PVC pipe. Someday a plumber will thank you for not killing him or killing his sawzall....or, to a lesser extent, some electrician will thank you for not causing him to waste time looking for the wire that "should be right next to this pipe".
jproffer is offline   Reply With Quote
Old 07-28-2014, 01:12 AM   #4
Okay, I figured out what Roxal is, but what is NMD 60 ? Google comes up with nothing relevant.
Toller is offline   Reply With Quote
Old 07-28-2014, 01:19 AM   #5
Mad Scientist
In context, I'd say it's Non-Metallic cable, type D (Romex suitable for damp locations, used only Canada), with conductors rated for 60C, as opposed to the 90C rating of modern NMD90.
McSteve is offline   Reply With Quote
Old 07-28-2014, 07:10 AM   #6
joed's Avatar
NMD60 is the Canadian equivalent of NM cable. Non Metalic Dry, 60C temp rating.
The cable for wet locations would be NMW.
Old 07-28-2014, 09:27 AM   #7
so should it be protected with anything?
I would have thought this to be dangerous given the 60 deg celcius rating
Old 07-28-2014, 10:12 AM   #8
joed's Avatar
The question was is it safe to insulate around it. The answer is yes.
The part about the conduit is not relevant since it is safe to insulate around it.
Old 07-28-2014, 05:48 PM   #9
It's legal(USA) to insulate around it. There's an interesting thread in the Mike Holt forum about whether it's safe. British code from what I'm told requires treating the conductor as though it had only half its free-space current rating if it's buried in insulation. Field experience suggests that light-duty light and plugs circuits don't have a problem in practice but service entrances and high-current industrial cable can overheat. http://forums.mikeholt.com/showthread.php?t=162956
Run and find ou is offline   Reply With Quote
Old 07-28-2014, 06:55 PM   #10
joed's Avatar
Service entrance cable and wires in conduit can NOT be insulated entering a building in Canada.
Old 07-29-2014, 08:48 AM   #11
so you are saying my situation is neither, so it should be okay.
Old 07-29-2014, 09:09 AM   #12
joed's Avatar
You are fine to insulate the NMD60.
Question about drilling to run cable...hit metal plate. chrisngo Electrical 3 01-19-2014 08:48 PM
question about NMD-60 cable gramps416 Electrical 13 11-19-2013 09:44 AM
I need to test a cable for a kitchen range justplumducky Electrical 4 10-21-2012 11:23 PM
Armored cable shell as conduit? sixspeed Electrical 13 10-18-2012 03:45 PM
SOOW cable usage question CAD Electrical 10 10-16-2009 11:33 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
