-   -   re: older NMD 60 cable question (http://www.diychatroom.com/f18/re-older-nmd-60-cable-question-204247/)
gramps416 07-27-2014 09:01 PM
i have a wall i wish to insulate with roxul safe and sound. I have some old cable NMD-60 that is hooked up to stove in that wall. (i don't know the gauge off hand). I want to know if i should avoid insulating this area, or is it safe to insulate around NMD-60
Is there something i could do if it is not safe? like maybe putting some PVC pipe around it?
thanks
joed 07-27-2014 10:19 PM
You are OK to insulate around it.
jproffer 07-27-2014 11:24 PM
If you do feel the need to put something "around" it (not sure how you'd get it around it), please please PLEASE don't use regular white PVC pipe. Someday a plumber will thank you for not killing him or killing his sawzall....or, to a lesser extent, some electrician will thank you for not causing him to waste time looking for the wire that "should be right next to this pipe".
:thumbsup:
Toller 07-28-2014 01:12 AM
Okay, I figured out what Roxal is, but what is NMD 60 ? Google comes up with nothing relevant.
McSteve 07-28-2014 01:19 AM
In context, I'd say it's Non-Metallic cable, type D (Romex suitable for damp locations, used only Canada), with conductors rated for 60C, as opposed to the 90C rating of modern NMD90.
joed 07-28-2014 07:10 AM
NMD60 is the Canadian equivalent of NM cable. Non Metalic Dry, 60șC temp rating.
The cable for wet locations would be NMW.
gramps416 07-28-2014 09:27 AM
so should it be protected with anything?
I would have thought this to be dangerous given the 60 deg celcius rating
joed 07-28-2014 10:12 AM
The question was is it safe to insulate around it. The answer is yes.
The part about the conduit is not relevant since it is safe to insulate around it.
Run and find ou 07-28-2014 05:48 PM
It's legal(USA) to insulate around it. There's an interesting thread in the Mike Holt forum about whether it's safe. British code from what I'm told requires treating the conductor as though it had only half its free-space current rating if it's buried in insulation. Field experience suggests that light-duty light and plugs circuits don't have a problem in practice but service entrances and high-current industrial cable can overheat. http://forums.mikeholt.com/showthread.php?t=162956
joed 07-28-2014 06:55 PM
Service entrance cable and wires in conduit can NOT be insulated entering a building in Canada.
gramps416 07-29-2014 08:48 AM
so you are saying my situation is neither, so it should be okay.
joed 07-29-2014 09:09 AM
You are fine to insulate the NMD60.
Copyright © 2003-2014 Escalate Media LP. All Rights Reserved
