Old 10-05-2008, 02:13 PM   #1
RE: Kenmore Dishwasher (Not New)
Hello everyone,
I am a computer guy not handyman however in this day and age it is cheaper to do things for yourself. So my question is this, I have a wire coming from the wall I am not sure if it's 220 or 110 how ever it is a thick White outter wire with a White, Black and looks to be Copper Wire. On my dishwasher I only have a black and white wire. I am assuming the white goes to white and the black goes to black but where does the copper wire go to?
Thanks,
Michael
houstonpcguy is offline   Reply With Quote
Old 10-05-2008, 02:26 PM   #2
Electrician
The bare copper is for the ground, there is usually a green screen that you wrap the wire around.
If there is no screw you can usually put a screw in yourself and use that. You would put the screw in the same place where the wire comes in, as long as it is metal.
darren is offline   Reply With Quote
Old 10-05-2008, 02:34 PM   #3
Thank you very much Darren, That's what I figured now my next question is, Do I ground it to the dishwasher or do I have to find something in the kitchen to ground it to, because I don't think there is anything to ground it to in there, where it is located?
Thanks again for your help.
Michael
Old 10-05-2008, 03:38 PM   #4
Electrician
The few dishwashers I have installed the wires comes into a small metal enclosure(this is where you will find the knock out that the wires come through) and this is where it would get grounded.
The other end of the bare copper will be attached to the ground bar inside your panel.
Old 10-05-2008, 04:49 PM   #5
Electrician
SD515's Avatar
...The other end of the bare copper will be attached to the ground bar inside your panel.
Which if is properly installed, would already be hooked up.
Additional note...(I'm bored today)...there is a proper way to attach a looped wire around a screw. Orientate the wire so it is pulled on to the screw when tightened. If the wire is coming to the screw from below it, the wire would go on the left...hence tightening the screw will pull it on, instead of pushing it off. (Told ya I was bored...)
Kyle
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
Kenmore Dishwasher Rinse Aid Draining Tate71 Plumbing 7 07-30-2008 10:41 AM
Kenmore Portable Dishwasher Won't Drain - PLEASE Help! katb1030 Appliances 8 07-10-2008 01:38 PM
Kenmore Dishwasher HELP!! eric-c Appliances 2 06-25-2008 06:07 PM
Kenmore Ultra Wash Dishwasher mystery rtyui2 Appliances 3 05-29-2008 11:35 AM
