Old 02-10-2011, 01:58 PM   #1
Re-Certified, Re-Furbished Circuit Breakers
While searching online for Combination Arc Fault Circuit Breakers ($40-$60) I ran across some Re-Certified and Re-Furbished breakers that cost less ($20-$30 about half price of new). Has anyone had any experience with re-built breakers? Do I understand correctly that according to the newest code a large part of the household circuits must now be protected by Combination Arc Fault Breakers? This could get expensive as normal breakers are about 1/10 the price of AFC's.
i_need_help is offline   Reply With Quote
Old 02-10-2011, 02:51 PM   #2
Master Electrician
If your home was code compliant when it was built and/or rewired it does not have to be brought up to current codes unless you are altering or rewireing.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
i_need_help (02-11-2011)
Old 02-10-2011, 03:14 PM   #3
Just to clarify, this is new construction.
Old 02-10-2011, 03:30 PM   #4
Licensed electrician
The breakers might be just the older style arc-fault and not the newer combination arc-fault.
Old 02-10-2011, 05:32 PM   #5
Electrical Contractor
All I can say is don't do it.
It may cause more headaches than the few bucks you save.
What brand are you looking at?
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
Old 02-10-2011, 08:23 PM   #6
Electrical Supplier
Just dont do it. doesnt matter the brand.
you get what you pay for. Pay cheap, it is more likely to be a problem.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
The Following User Says Thank You to LyonsElecSupply For This Useful Post:
2 breakers / 1 circuit dn100 Electrical 3 10-03-2010 09:01 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 01:34 PM
Circuit Breakers Unregistered Electrical 4 09-13-2004 09:49 AM
