RCA Television - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 04:10 PM   #1
Rewards Points: 27
RCA Television
I have a 27" RCA television that continually blows a fuse. The fuse is located on the backside of a circuit board, and the power cord is wired to the opposite side. When the fuse is replaced with the same size fuse, the tv powers up for just a second or two, then the blows the fuse. Any one have any thoughts on how to fix?
cm3putter is offline   Reply With Quote
Old 09-26-2009, 04:45 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
cm3,You don't have a short but there is a faulty component drawing much more current than normal which causes the fuse to blow. The fix is to replace the faulty component.
IMO if the TV is more than three years old, it not worth trying to fix the TV.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 09-26-2009, 06:19 PM   #3
Search the Internet for someone who has solved this for your particular TV.
Or. . .
Substitute a power resistor for the fuse of value such that the current is small enough not to smoke the TV but large enough to trace where all this current is going.
With a schematic and a bench full of equipment it might take you hours to find the problem.
If the new part you put in also fails within a day, week, or month, it means you haven't yet found the root cause.
Old 09-26-2009, 06:32 PM   #4
Rewards Points: 1,512
A common fuse blowing problem for old TV sets and other electronics, both all-tube and solid state, is a shorted filter capacitor.
You will need electronics know-how to find and replace it.
Old 09-26-2009, 06:36 PM   #5
I'd figure on the flyback oscillator 'sistor for a solid state set.
