Old 09-06-2008, 11:05 AM   #1
Rca / Phono Leads Shared Ground Ok?
RCA/PHONO leads with a number of video & sound outputs (Eg. Vid1, Snd1 L/H, Snd1 R/H, Vid2, Vid3 and one ground) is it ok to use 'A' shared ground for all outputs?
srands is offline   Reply With Quote
Old 09-06-2008, 12:22 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
No, due to if talking A/V, it will not only not work, but will introduce noise into the sound & audio circuits.
Old 09-06-2008, 01:15 PM   #3
OK, would 'A' shared ground with RCA/PHONO leads be OK on just VIDEO outputs?
Old 09-06-2008, 07:08 PM   #4
Keep the gnds separated, in a/v systems a common ground creates interference, and possibly worse problems.
rgsgww is offline   Reply With Quote
Old 09-06-2008, 08:24 PM   #5
gregzoll's Avatar
Again no, due to the system is not designed that way. Common grounding leads to noise induced problems, among other things. Also keep in mind, that with each channel, the Ground acts as the return path for that channel, so why create a common Negative path?
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Ground question. mystery guest Electrical 5 07-24-2008 01:47 PM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
