Range Wiring Question - Not Usual Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 01:20 PM   #1
I would like to wire a range in my garage for powdercoating only. I plan on using an old electric home range for this use. I currently have an outlet for my welders that I would like to use for this range as well, but I do not know how to go about wiring it up.
The welding outlet is a 3-prong Hot(240v)-Neutral-Ground. I know ranges are 240v, but if I am not mistaken, they are Hot(120v)-Hot(120v)-Neutral-Ground(if used). Am I correct in believing that?
My question is, can I use my dedicated 240v line to run this range, or is that not possible?
Any help would be greatly appreciated. Thank you.
RWessner is offline   Reply With Quote
Old 12-04-2010, 02:12 PM   #2
DIY staff
Rewards Points: 7,174
Retest that existing outlet--240 is always made up from two 120 legs---open up your breaker box and take a look.
Old 12-04-2010, 02:51 PM   #3
answer is no, your welding plug has no neutral. 3 prongs are hot-hot-ground, when you test you will get 120 to ground on each and 240 between the 2 "hot" wires. Ranges need a 3wire+ground (red/blk/wht/bare/) hope it helps
dhubz is offline   Reply With Quote
Old 12-04-2010, 03:19 PM   #4
Rewards Points: 150
? How is your welder wired?
installing a 3-wire receptacle for a range isn't up to CURRENT code but it was once common - and I'm sure the local inspector isn't going to come chase you down for plugging a range into the welder outlet, IF the circuit rating, cable size, and socket are correct.
emolatur is offline   Reply With Quote
Old 12-04-2010, 06:43 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,... Exactly,... I'd do it in a heartbeat, especially for such a tempory situation...
Old 12-04-2010, 06:44 PM   #6
Thank you all for your replies. You are all, of course, correct.
I knew it just wasnt making sense in my brain, and I am very glad I asked. Just finished wiring the range now, and it works perfectly.
Thank you all.
The Following User Says Thank You to RWessner For This Useful Post:
oh'mike (12-04-2010)
Question about series wiring. Chevyman30571 Electrical 7 02-26-2010 08:54 AM
Electrical Box Wiring Question OmahaGirl Electrical 9 02-18-2010 08:03 AM
wiring new GFCI breaker question dgates12 Electrical 8 01-07-2010 12:14 PM
Electric/Gas Range Question txrun Electrical 3 12-23-2009 08:25 PM
Range Wiring jasjks Electrical 2 09-01-2006 11:37 AM
