-   -   Range Wiring Question - Not Usual Question (http://www.diychatroom.com/f18/range-wiring-question-not-usual-question-88589/)
RWessner 12-04-2010 01:20 PM
I would like to wire a range in my garage for powdercoating only. I plan on using an old electric home range for this use. I currently have an outlet for my welders that I would like to use for this range as well, but I do not know how to go about wiring it up.
The welding outlet is a 3-prong Hot(240v)-Neutral-Ground. I know ranges are 240v, but if I am not mistaken, they are Hot(120v)-Hot(120v)-Neutral-Ground(if used). Am I correct in believing that?
My question is, can I use my dedicated 240v line to run this range, or is that not possible?
Any help would be greatly appreciated. Thank you.
oh'mike 12-04-2010 02:12 PM
Retest that existing outlet--240 is always made up from two 120 legs---open up your breaker box and take a look.
dhubz 12-04-2010 02:51 PM
answer is no, your welding plug has no neutral. 3 prongs are hot-hot-ground, when you test you will get 120 to ground on each and 240 between the 2 "hot" wires. Ranges need a 3wire+ground (red/blk/wht/bare/) hope it helps
emolatur 12-04-2010 03:19 PM
? How is your welder wired?
installing a 3-wire receptacle for a range isn't up to CURRENT code but it was once common - and I'm sure the local inspector isn't going to come chase you down for plugging a range into the welder outlet, IF the circuit rating, cable size, and socket are correct.
Bondo 12-04-2010 06:43 PM
Ayuh,... Exactly,... I'd do it in a heartbeat, especially for such a tempory situation...
RWessner 12-04-2010 06:44 PM
Thank you all for your replies. You are all, of course, correct.
I knew it just wasnt making sense in my brain, and I am very glad I asked. Just finished wiring the range now, and it works perfectly.
Thank you all.
