Old 10-22-2005, 06:09 PM   #1
Range Wiring
The breaker on our range tripped recently. I found the terminal block burned, and replaced the plug/block/ and portions of the wiring from the block that were dammaged. The wire from the block is stranded 12AWG, which seemed a bit skimpy to me. I fired up all four burners and measured 28A on the 12 awg wire. Are there different standards for internal wiring or does the 20A limit still apply?
merlin is offline   Reply With Quote
Old 11-20-2005, 12:00 AM   #2
ryaniniowa's Avatar
Range Wiring
Yes, the #12 stranded you are looking at is a high temp wire capable of handeling much higher current flow then the standard romex.
ryaniniowa is offline   Reply With Quote
Range outlet required? Doug_Shaver Electrical 2 06-12-2007 06:10 PM
Range Wiring jasjks Electrical 2 09-01-2006 12:37 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 06:03 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 06:12 PM
