Range Wire Size - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 04:58 PM   #1
range wire size
I will be replacing about 30' of aluminum wire from a 50 amp breaker to my electric range. What size copper wire should I use? Thanks.
mikalino is offline   Reply With Quote
Old 02-12-2009, 05:05 PM   #2
6/3 w ground Copper NM. I'm assuming you're going to use cable and not conduit?
jerryh3 is offline   Reply With Quote
The Following User Says Thank You to jerryh3 For This Useful Post:
mikalino (04-21-2010)
Old 02-12-2009, 05:15 PM   #3
Yes and thanks for your quick response. moparman
Old 02-12-2009, 07:56 PM   #4
Or, 99 percent of the time, 8/3 and 40 amp.
220/221 is offline   Reply With Quote
The Following User Says Thank You to 220/221 For This Useful Post:
Old 02-12-2009, 08:45 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Why do you do this to me are you trying to give me gray hair? He is replacing a old cable. The branch circuit must be 4 wire.... you forgot your G at the end of the 8/3........
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
Old 02-12-2009, 08:52 PM   #6
Isn't "with ground" the default type?
Old 02-12-2009, 08:52 PM   #7
8/3 WITH GROUND
Do they make ungrounded NM anymore?? I did somehow end up with some white 10/3 no ground a couple years ago. I assumed it came from a boneyard somewhere.
Old 02-12-2009, 09:01 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Yes as a matter of fact they do but it is hard to find......
Stubbie
Old 02-12-2009, 09:06 PM   #9
Yes....as a matter of fact, it is
Old 02-12-2009, 09:06 PM   #10
99%? Were talking about freestanding ranges, right?
Old 02-12-2009, 09:33 PM   #11
Yes. I have seen only one range that required a 50 amp circuit.
To date, I have seen a total of 100 ranges.
Old 02-12-2009, 09:52 PM   #12
Sure, make me go look at my range, wire, look up the installation instructions
50a breaker, #6 wire by the looks - older wire in metal flex conduit. Stove has factory 3 wire cord I think. Stove rated at 13.5 kw
Instructions say 50a - so looks like I'm good
Pretty sure I checked all this when I had SF buried, new panel installed
Any reason to replace the wire?
If it's not a 4 wire connection/outlet should I upgrade it?
And can I use the conduit as ground? It's continous & connected
Kitchen will be remodeled in the next 2 years
Plenty of slack as the stove will move 12" closer to the panel
Hey - now you've "seen" (2)
The Following User Says Thank You to Scuba_Dave For This Useful Post:
wire size for solar generator? krisman Electrical 12 01-28-2009 11:34 PM
Wire size for dryer jamiedolan Electrical 14 01-15-2009 06:43 AM
Wire size for sub-panel deepstuff Electrical 12 11-22-2008 01:08 PM
Choosing Proper Wire size PowerEight Electrical 15 05-22-2008 01:58 AM
Circuit breakers and wire size stan 41943 Electrical 19 03-06-2008 03:29 PM
