Range Question- Common Question But Eager To Learn Info! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-12-2012, 06:37 AM   #1
langless28's Avatar
Rewards Points: 152
range question- common question but eager to learn info!
i have an electric range/double oven and the instructions state that it needs a MINIMUM of 40amp 240v dedicated circuit. the label on the front states that at 120/240v its rated for 13.8 Kw. isn't there a NEC code that states ranges over 12 Kw need a 50 amp circuit?
out of curiosity because i don't know a whole lot about commercial power, the label also says at 208Y/120v the power rating is like 6 or so Kw; is that 3 phase power?
langless28 is offline   Reply With Quote
Old 10-12-2012, 07:04 AM   #2
Resi EC
Rewards Points: 252
Table 220.55, Note 1, would apply
Table 220.55 Column C is for ranges from 8 3/4 to 12 kw.
For 1, 12kw rated range a demand of 8 kw is allowed.
Note 1. For ranges over 12 kw 5% shall be added for every kw and major fraction. (in a nut shell)
So with a 13.8 kw range it would be 8kw + 10% = 8.8kw
8800/240= 36.6, next higher would be 40a
If my math is incorrect I'll be corrected by someone
Yes 208/120 is for 3 phase.
Gac66610 is offline   Reply With Quote
Old 10-12-2012, 10:31 AM   #3
langless28's Avatar
Rewards Points: 152
that is crystal clear! thanks, i have the 2011 nec pocket edition at home and i will double check. i have read heated arguments in the past on here about whether its better to just run a 6/3 w/50amp rather than a 8/3 with 40 amp to "future proof" the kitchen.
its a starter home so i will most likely do the 8/3 with 40amp breaker.
Old 10-12-2012, 06:57 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It really doesn't matter what the NEC states, you have to go by the manufacturer's instructions. They, in a sense, trump the code.
Old 10-12-2012, 08:03 PM   #5
langless28's Avatar
Rewards Points: 152
yes i have heard that, the instructions explicitly state a MIN of 40 amp circuit; that leaves interpenetration that 50 amp is suitable as well.
now quoting office space, is the BARE minimum in this case worse or is perfectly adequate and recommended?
Old 10-12-2012, 08:14 PM   #6
k_buz's Avatar
Perfectly adequate
Receptacles Behind Gas Range Install - Question IIchrisII Electrical 4 07-27-2009 08:37 PM
New range hood question drtbk4ever Appliances 5 05-26-2009 09:56 AM
Range hood wiring question, help!! nyc_apt_dweller Electrical 4 03-05-2009 08:34 PM
range fan installation question Jeremy Hillary Boob, PhD Electrical 3 01-15-2009 04:06 PM
3 Prong Range Hook up question tulsa442 Electrical 20 04-15-2008 09:58 PM
