Range Pigtail - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 09:47 AM   #1
Range pigtail
My daughter and son-in-law bought me a new smooth top electric range for Christmas. We put the old range in the basement for me to can on, since the canner would be too heavy for the smooth top range.
We placed it next to the dryer, thinking we could just unplug the dryer and plug in the range when needed - however, the pigtails are different and the dryer is 30amps and the range 50 amps.
Can we change the pigtail on the range since I'll only be using one burner for canning ? (The oven no longer works)
Thanks for your help.
Yak1939 is offline   Reply With Quote
Old 04-10-2012, 09:49 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Not legally
Old 04-10-2012, 10:18 AM   #3
Rewards Points: 13,446
It needs it's own circut and a 50 amp double breaker.
Old 04-10-2012, 11:03 AM   #4
Rewards Points: 126
If the receptacle is installed with conduit you can easily pull out the existing wires and pull in the correct wires for a range circuit.
Old 04-10-2012, 11:04 AM   #5
k_buz's Avatar
But then they wouldn't be able to use the dryer.
Old 04-10-2012, 02:05 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,920
I don't think it would be too big of a deal to run it on a 30A circuit for canning. One unit won't even come close to 30A. If you do exceed it, the breaker will trip before anything bad happens. It's not code compliant, but it's not really dangerous either.
mpoulton is offline   Reply With Quote
Range pigtail starfish1215 Electrical 2 12-06-2011 10:16 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 05:39 AM
