Range Pigtail - Electrical - DIY Chatroom Home Improvement Forum
Old 12-06-2011, 09:34 PM   #1
Exclamation
Range pigtail
I just bought a used maytag MEP5770AAB and it did not come with a pigtail so I bought one from Home Depot. When I attempted to put it on I saw that there were bolts on the screws that the pigtail attaches to. I tried to unscrew these bolts assuming that I put them back on over the pigtail but they will NOT come undone. Im not sure if they are suppsed to be there and I attach the pigtail and just add more bolts or if they are supposed to come off. If they are supposed to come off then I dont know what to do because 3 people have tried to get them off and they will not come undone.
starfish1215 is offline   Reply With Quote
Old 12-06-2011, 09:54 PM   #2
Rewards Points: 6,652
Post pictures of the pigtail where it plugs in, the end that connects to the block, and the range. Usually you just loosen the Phillips head screws on the block for the Red, White, Black, and slip the connector on the end of the wire under that particular screw and then tighten down the screw to be snug. The Green, which is ground, does not connect to the White, which is Neutral, but would be on its own with the Green from the Pigtail. That would be a 4-wire connection. 3-wire connections are "bonded" with Neutral & Ground as one.
Old 12-06-2011, 10:16 PM   #3
Thank you for your reply. I will post pictures tomorrow (not at the house with the range). I dont understand what you mean by loosening the screws and slipping the pigtail in behing them then tightening the screws down. The ends of the pigtail that I have are complete circles. I will send pictures tomorrow so that you can better understand. Im at a loss.
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
120v gas range wiring question Redfishjoe Electrical 5 05-11-2011 09:37 PM
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 05:39 AM
